Question about Leviton 8599 GFCI Receptacle
Sodium security blinks on and off all night , has replace bulb and works for about a year. then the blinking starts back
  • 34 Answers
Is there another light in the vacinity or is the light in question itself pointed at the photocell. most likely scenarios are that the light is pointing at its own photocell so when it is off the photosell senses dark and turns it on but then when light comes on tricks photocell into thinking it is daylight,check position of photocell and adjust away from light source if problem persist could be ballast going bad
Posted on Oct 10, 2009
Blinking picture
Replace bulb and heave all cooling vents cleaned of dust. Bulbs on rear projection sets are more like street lights than regular home light bulbs. They dont just burn out they start in and out and maybe fading before they die.
May 09, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
2005 Montana SV6 right front turn signal not working correctly
might try to replace the turnsignal relay which is under the dash i belive, it is round and looks like a very small container about 1inchx1inch...If you replace that and it does the same thing you have a short in the wiring harnes that leaders from the blinkers to the actuatore, or a bad ground, start by chasing the ground and making sure they are all tightly secures with no bare wire/ or pinched wires anywhere..
Hope this fix's'ya!
May 19, 2009 | 2003 Pontiac Montana
Security light goes off and on
if it is a gas bulb (mercury vapor, metal halide, or high pressure sodium) the bulb needs to be replaced. they "cycle" when they go bad for a few weeks then completely stop working
Apr 08, 2009 | Leviton 8599 GFCI Receptacle
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Chevy Cavalier 2001 turn signal blinks fast
If new bulbs don't work, it is probably the harness that holds the bulb. I had to replace both on my car after fighting with the problem for over a year and not knowing.
Nov 26, 2008 | 2001 Chevrolet Cavalier
I have owned a Sony rear projection TV for a little over two years. Model KP-51HW40. I have two problems. The first problem has been going on for about one year. Most of the time when, it is first turned...
Problem # 2 is a convergence issue. If you can solder, you can repair this yourself. As far as problem #1 goes, count the blinks. The set goes into standby as protection from further damage when a problem is detected. The blink count is an internal diagnostic that indicates the circuit in which the problem was detected. Report back here with the blink count if you can.
I'll look up the convergence IC numbers in the mean time.
Dan
Apr 24, 2008 | Televison & Video
Leviton 8599 GFCI Receptacle Logo
331 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
