Question about Kodak EasyShare DX3700 Digital Camera
What if your camera has the green light on then turns off but the screen becomes blue wht does that mean
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
Rewiring 1968 cutlass I need color codes
The wire color code is as follows:
BLK= Black
BRN= Brown
RED= Red
ORG= Orange
YEL= Yellow
GRN= Green
BLU= Blue
GRY= Grey
WHT= White
PPL= Purple
PNK= Pink
TAN= Tan
LT BLU= Light Blue
DK BLU= Dark Blue
LT GRN= Light Green
DK GRN= Dark Green
Let me know if you require any further assistance.
Oct 20, 2010 | Oldsmobile Cutlass Cars & Trucks
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
Green screen on Toshiba 34N9UXE
you can have a bad CRT, a bad chroma module, either one can show the symptoms you are describing. You will need a TV repair tech for the right diagnosis.
Jun 02, 2009 | Toshiba Satellite A105 Notebook
Connecting my cd stereo to 1990 Ford Taurus
since it worked before and you didnt change anything and now there is no power it looks like you blew a fuse when connecting wires. check the radio fuse on the door panel, and check the int. lighting fuse under the hood of the car. take both out and see if they are blown, if blown buy new fuses and replace.
heres the wiring diagram for a 1990 Ford Taurus:
Left Front (+) orange/lt green
Left Front (-) lt blue/white or Blk
Left Rear (+) pink/lt green
Left Rear (-) dk blue/ orange or Blk/Wht
Right Front (+) Wht/Lt green
Right Front (-) Dk green/ orange
Right Rear (+) pink/Lt blue
Right Rear (-) Tan/White
Lt green/yellow Hot at all times
Black - Ground
Yellow/Blk - Ignition
Lt blue/red - Acc
Orange/blk - Dimmer Lights
RED - Lights
Aug 22, 2008 | Car Audio & Video
TV Picture cuts off.
The blue screen means that you have lost signal. If the set don't have signal for so long it turns itself off. "power saver feature" Check all connections or replace cables, If that don't work the signal board may be going bad.
Feb 26, 2008 | Televison & Video
Ceiling Fan wires
you don't have the necessary wires. you need to run a 3-wire cable (wht, blk, red, grd) between fan+switch. then post bac for instructions...
Dec 12, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Kodak EasyShare DX3700 Digital Camera Logo
13 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
