Question about HP LaserJet 4600dn Color Printer
Color rolling onto paper
Our 4600dn laser printer is lightly "rolling" yellow and red ink onto the paper as it prints, so the entire paper ends up colored. What is wrong?
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
  • 5 Answers
SOURCE: I have an HP 4600dn that is having trouble printing color.
first try the color calibaration in the printer
then adjust the x-axis & y-axis in the registration area
if both options not working cold reset the printer
Posted on Jan 09, 2008
  • 1894 Answers
SOURCE: hp color laser jet 4600dn printer on network will not print turn printer off back on will print
HELLO DUDE
Posted on Mar 07, 2008
printech
  • 159 Answers
SOURCE: Hp Color laser jet 2600 printer making too much noise
check pickup roller and the sap ration bad
Posted on Mar 09, 2008
chrlygrn
  • 149 Answers
SOURCE: HP color laser 4600dn FAN noise
Yes this is normal. Everytime someone prints, the printer exits power saving mode and the fan will stay on. If you leave it on and don't print to it overnight, the fan would shut off in the mornig. But you probably turn the printer off everynight and are printing all day, so you don't really have to expectthe fan to power down unless its not being used for an long period of time idleing.
Posted on Jul 18, 2008
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Tip
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Our older 4600dn when a laser label is used sometimes does not fix the color for very dark or high contrast colors changes. Also following print on any paper laser or reg get a blotch of this dark color...
Sounds like you have a fuser issue. Also, there is a wire inside the unit that creates a magnetic charge on the pager that attracts the toner. If the paper is too thick, this wire is failing, or the fuser unit itself is going bad then the toner cannot be "attracted" to the paper because the magnetic charge is either too weak or altogether absent.
You could probably get the unit serviced, but the price of network printers with duplexing are quite low and may be less expensive than getting this one repaired.
Nov 19, 2009 | HP LaserJet 4600dn Color Printer
Lines down the paper HP 4600DN
This means that the problem is with the toner drum. Just try to clean the drum of the toner with cotton. It is green colored rod in the toner. then try to take the print. If still you get the line while printing please either replace the toner or get the drum replaced from a local vendor
Jul 14, 2009 | HP LaserJet 4600dn Color Printer
Blue lines accross my color printouts. They are on one side of paper. Hp color laser 4600dn.
YOur printer is dirty need to clean it with q tip and acohol use flashlight you will see where ink is built up
Jul 08, 2009 | Epson Aculaser C1100 Printer
Blurry, Ink Smeared pages
If the media (glossy paper) is designed for an ink jet printer you should be fine.
Ink has to be able to be absorbed into the fibers of the page. If you are using paper for a laser color printer, that's your problem.
Don
Jun 19, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
Ink spots on paper
If the spots are all one color, the toner cartridge of that color has a problem. Check the drum on that cartridge and make sure there are no bad spots on it. Your cartridge could be leaking toner.
Feb 27, 2009 | HP LaserJet 4600dn Color Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP LaserJet 4600dn Color Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
