Question about HP CP3525DN Color LaserJet Printer
I have a hp cp3525dn printer. How do you override
I have a hp cp3525dn printer. How do you override or reset the chip on the toner so you can use all of the toner and not be "throwing it away"? Is there a universal chip that can be used that won't "count copies"?
How do you use the chip? does it take any special tools?
I am new at this and don't want to make any mistakes.
Thank you.
SOURCE: Replacement toner cartridge chip not registering--1000.1 supply error
Use the override supplies out feature on the printer.  If the error still stops the printer from working put in the old hp chip and again use the override out setting. GO TO >system setup>print quality>replace supplies>override out,
Posted on Oct 26, 2007
printech
  • 159 Answers
SOURCE: HP 4100 Toner out
please tray to reset printer cold reset turn the printer off then press the go button then turn the printer on stay press go button when the message on control panel appear cold reset
Posted on Mar 19, 2008
SOURCE: Need to override the toner
Changed printer!!
Posted on Nov 05, 2008
leroyal
  • 2120 Answers
SOURCE: LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
Posted on Jan 22, 2009
SOURCE: printer doesn't work with refilled ink cartridges
use the ciss system from jet or some other brand it work great i am using from last two tp three month.
Posted on Mar 15, 2009
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
Our office manager ordered HP 42X toner cartridges for our HP laserjet 4240 printer. We previously used the HP 42 A cartridge. She thought this dual pack of the 42X would be more economical, but our...
If the toner is getting seated in the printer then you can just replace the smart chip on the toner with the old one which you have and this should work well. Try and do rate my solution.
Thanks
Jun 27, 2011 | HP Compatible For HP Q5942X Toner...
How to reset hP 2600 colour printer chip
When you refill an HP color laser cartridge you need to replace the SmartChip, as I do not believe that there is any way to reset the chip. Any reputable seller of toner would include the chip with the toner order. The are for sale on Ebay
Apr 11, 2011 | HP Color LaserJet 2600n Printer
Magenta color problem
This can be caused by one color not printing ...either from the lack of toner or the cartridge not being seen as full ..To reset them follow this procedure..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
This will override the toner level in the cartrdges and allow it to print all colors..and probably get rid of teh problem ..Usually the magenta predominant printing is caused by the lack of yellow color ..so watch it cause this one might empty first and cause it again if this procedure fix it for now ..There is a possibility that it is already out ..(empty )
Jan 28, 2011 | HP Color LaserJet 2600n Printer
Toner exhausted error is showing after refilling.
A reset chip is available from several vendors that overrides the printer's internal counter. This reset chip is installed on the motherboard, either by hooking tiny wires around the contacts of an IC chip, or by soldering. This reset chip is becoming easier to find. Check out ebay and other online vendors.
good luck, and rate the solution if helped
Nov 27, 2010 | Samsung CLP 315 Laser Printer
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
Thank you for contacting FixYa with your printer inquiry.
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
Hope this helps. Please keep us updated and remember to rate this answer.
May 19, 2010 | HP LaserJet P4015N Printer
Refilling toner for Samsung clp 315
Dec 19, 2009 | Samsung CLP 315 Laser Printer
Refilled a Lexmark c910 black toner cartridge. Still reads low or empty. Any way to override chip signal to printer so it still prints.
Yes you understand, it is problem Toner chip.When finished your toner then it chip has been disable.It is a technical policy.If you can refill it and again use.You must be reset the chip.Help www.chip resetter.com
Dec 06, 2009 | Lexmark C910 Printer
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
Feb 02, 2007 | HP Color LaserJet 2600n Printer
HP CP3525DN Color LaserJet Printer Logo
589 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
