32wlt58 i have tried to retune my tv due to a local upgrade and have lost all digital tv channels how can i get them back?
    Novelist:
    Champion:
  • 210 Answers
Some transmitters are having upgrade issues due to the switchover.
Do a mains reset and try again, power the TV by the button on the front of your Tosh and then pull the mains lead out, now press the power button on the front again, this will reset the DTV filters inside.
Now plug the mains back in and re-tune, if its still the same then find out if your local transmitter is having problems, if they are not then you may need to get an aerial installer out, but just make sure before that you have checked all your connections, also check the signal strength on the TV to see if you have any signal......if its full signal you may have too strong a signal and will need to have a attenuator fitted to reduce the strength of the signal.
Thanks
Posted on Oct 01, 2009
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I have retuned my parents tv but now the digital (freeview) channels do not have the correct channel numbers and I cannot find anything in the manual as to how to change them. For example, freeview channel...
It sounds like the TV has re-mapped the channels incorrectly. You possibly can contact Toshiba to see if there is a firmware/software upgrade that will fix this issue. If there is you may be able to download the software off of their website and install yourself. Just make sure if that is the case follow the directions carefully. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
Digital channel mix up
your cable company is moving the channels around. they are doing a major upgrade
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Oct 17, 2009 | Televison & Video
Bbc1 and 2 on freeview lost
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jun 20, 2009 | Panasonic 50 in. Plasma TV
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
