Question about GE WSXH208A Front Load Washer
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Posted on Oct 03, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Items not dry enough after spin cycle, some water remains in machine
This is normal. It depends on a number of factors, including the type and volume of clothing you are trying to wash. Usually, it is not a machine issue.
Dec 06, 2013 | GE Washing Machines
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes are still soaking wet after spin cycle
But is the washer empty, if there is still some water in it, there could be something in the drain line,
if all the water is gone, then it sounds like the washer is not reaching the full speed of the spin cycle.
Unless someone can remove the drain line and check the pump, and check the clutch of the machine,
I am sorry to say you should call an appliance person and have them make a service call.
If you where to post the model # of the washer, someone could look at the manual of it and see
how the washer works and what the pump is. I hope it is a simple fix for you.
Mar 21, 2009 | Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Damaging clothes
How long is the gentle cycle?. I prefer to make my own delicate cycle. I let the machine fill, agitate about 1 min. then turn off and let soak about 15 - 20 min. Make the machine pump out and start spin very briefly. stop machine. let fill up again and repeat to rinse. Don't let agitate for more than 3 or 4 min total wash and rinse don't let spin completely.
May 06, 2008 | Frigidaire GLTR1670A Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
GE WSXH208A Front Load Washer Logo
318 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
