Question about Filter Queen Majestic Canister Vacuum
I want to know easy way to change my filter - Filter Queen Majestic Canister Vacuum
    Problem Solver:
  • 6 Answers
There are only two. One on top and the paper cone filter that covers the entire base of the top. There are three paper tabs on the large paper cone filter. You can either put the filter directly on the bucket and then bend the tabs over the outer edges of the bucket to hold it in place and then sit the top down ( that's how I do it). Or you can put the filter on the plastic cone shaped frame on the bottom side of the top of the machine. It's actually easier if you flip it upside down and then flip the bucket base over onto it.
The only other filter is on the very top of the machine. Unscrew the top lid which is actually the cover for your exhaust hose inlet. This filter is indexed with a couple of screws that don't have to be removed. Spin the metal cover and remove filter. There is actually a large round filter ( hoop shaped on the top of the machine...I can't remember how I remove it, but truthfully it has little air restraining capacity so unless you have an odor issue with your Majestic what you can do is blow it out using the hose connected to the top of the machines exhaust blower outlet. Don't ever remove that filter, just literally leave it where it's at and put on your crevice tool and aim it through the slots around the top of of the machine.
Posted on Oct 07, 2009
Changed filter and bag. no suction, dust comes out of the front of the vacuum covers the vacuum cleaner.
If it is an upright vacuum cleaner you need to turn it over and remove the base plate. There are usually 4 easy turn tabs, or 4 screws. Under there on one side behind the brush, you will see a hole where the dust goes up into the bag. Yours will be blocked. Often a piece of stick, a hair grip or something blocks the hole and then the fluff builds up on it until fully blocked.
Let me know how you get on by clicking the COMMENT button on this post.
Dec 01, 2015 | Filter Vacuums
Will run for a few minutes, then red light comes on canister an unit shuts off.
That's the thermal cut off circuit. If the motor gets to hot it trips and shuts it off. When it cools down it will turn on again but it is generally an indicator of one of the following; the cone filter needs changed or the inner filter ring that sits above the motor inside the unit is shot. One is an easy change the other requires dis-assembly, better carried out by a vac tech if you aren't comfortable taking it apart. In the meantime remove the cap out of the top of the vacuum, that will let it exhaust heat better but I strongly recommend getting that filter ring changed.
Nov 27, 2015 | Filter Queen Majestic Canister Vacuum
My canister motor shuts off after a few minutes and a red light comes on
How to get the filter cover off
There's a "tab" at the top rear of the vacuum that must be depressed while pulling up on the filter cover.
You can then access the filter for easy changing.
With 30 yrs. experience, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
Hope that helps! Mick
Mar 07, 2015 | Electrolux Epic 6500 / 7000 legacy vacuum...
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
How to replace dyson dc17 post motor filter (not the main "washable" one under the canister).
You do not have to disassemble the vacuum to get to the post motor filter. The above person does not know the DC17 if they are telling you this.
You simply remove one Phillips head screw, it is Phillips because most consumers won't have a T-15 driver at home. Remove that screw, the cover pops off and you take out the filter and replace it.
Easy peasy
Sep 09, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Need replacement filter for Bissell Easy Vac Plus model 3102-0
I found a filter on GoVacuum.com It sells for 11.90 with free shipping.
Aug 22, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Filter Queen Majestic Canister Vacuum Logo
174 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
