Question about NorStar Meridian M7310 Phone
One of the telephones ringer volume has increased substantially to almost unbearable. Which Feature item is that? Greg
    President:
  • NorStar Master
  • 860 Answers
While the phone is ringing, press the down directional arrow below the dialpad. You can make the phone ring by pressing feature *80.
Posted on Oct 02, 2009
How to increase ringer volume on Alcatel one touch ?
The rocker volume is on the side of the phone. Up or down controls the volume.
Jul 01, 2016 | Alcatel Cell Phones
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
How do I cut ringer offhow do I put someone on hold andanswer another call
You may download a copy of the manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf.
To decrease the ringer volume, press DOWN while in standby mode.
Call waiting is a service offered by your telephone company, not a feature of any particular phone. To learn how to use it, contact your telephone company for their instructions.
Jul 18, 2013 | Uniden Dect1480-6 Dect 6.0 Cordless 6...
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
The telephone is on vibrate. How do I return it to ringer?
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day, 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Dec 05, 2010 | One Touch Jitterbug One-Touch Cellular...
Can't figure out how to turn the ringer on our Uniden 6.0
You can increase the ringer volume from the menu ... by the way Uniden DECT 6.0 Cordless phone basically have very low ring volume ,,, try using an extra ringer which is very cheap or you can make your self ... A simple circuit diagram available on http://www.electronics2day.com/index_files/Page790.htm
Nov 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
I need to make them ring
First check and see if the ringer is on or the volume is turned up.
1st press Feature *6 Press number keys 1- 4 to hear different ring types
2nd - check your volume (Press Feature *80 press volume key up or down
Jun 23, 2009 | NorStar M7324 Telephone
NorStar Meridian M7310 Phone Logo
133 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
