Question about Asko D1776 Stainless Steel Built-in Dishwasher
Asko D1996 lights flashing washer won't start
The four lights on the left flash, then the four lights to the right of them flash, alternating. When I reset the start by holding it down three seconds and then press wash and start, the lights start blinking again. There is no panel on the back of a D1996 Asko dishwasher to remove and wipe out the moisture.
Any ideas?
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Posted on Nov 03, 2012
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
SOURCE: Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Posted on Sep 18, 2009
localwonder
  • 6784 Answers
SOURCE: My ASKO D1996 Dishwasher will not turn on, checked
NO, you should get light actions even if the water was not connected. this is a main control issue. there is a control board kit available for your unit. you will need to replace this damaged control in this case. the logic sector is damaged.
Posted on Jul 19, 2009
  • 901 Answers
SOURCE: Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Posted on Apr 15, 2010
Daniel S
  • 4323 Answers
SOURCE: We need a new control
Hi
You can click on this link to buy control for your Asko D1996. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 09, 2011
What is the light "Sensing" means when flashing
its normal for the new washers to sense how or what type of load you put in it , first thing after start is pressed , if it stays in sense! then it has detected a fault , either the sensor or the load is at fault , try the manual setting and see what it does
Jan 10, 2015 | Watches
When i turn the signal lights for left or right turn the emergency flasher start flashing all four turn signal lights. the emergency flashers work ok
ck your turn signal switch wiring connector because it is more than likely has been hot and melted some connections.
Oct 18, 2014 | 2000 Kia Sportage
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
Possible causes
3. Fuse has blown.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Asko 1895
First make sure your door switch is making proper contact.If not replace it. If it checks out ok than your main control board is bad.
May 21, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
945 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
