Question about Xerox Phaser 8500/DN Printer
Phaser 8860 error code 08,030.46;21225
Anyone know what this error means?
  • vbshredder Oct 02, 2009
    where is the solution
  • 29 Answers
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Posted on Oct 28, 2009
Anyone know what this error is on a Phaser 8860?? 13,264,42:57563
Printhead Reservoir Thermal Fault.
13,264.42 indicates the heater is too hot.
Make sure the room temperature is within the printers operating range (not too hot in the room).
Check that the printer is plugged directly into a wall outlet that is properly grounded (3 prong plug, not 2 prong with an adapter)
Check the printhead connections and wiring. (Be sure to turn the printer off at least 30 minutes prior to touching the printhead area).
If all of these things are ok, then the printhead needs replaced.
Oct 21, 2013 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox phaser 8860
This unit has a common situation that requires parts and 2-3 hours of labor. This error points to a bad process motor 127K53240
These generally go bad with 2 camshafts 020K14800 and 008K02160
Whit
Item, Inc.
Jul 10, 2009 | Xerox Phaser 8560DN Printer
8860 print error 07,010.43;92622
print out comes after restarting the phaser 8860 printer and stops after sometime
Jul 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8860 error code 34,015.48:66749
Hi
Cyan Ink Level Sense Fault (34,015.48)
You must have a minimum of something like 3 ink blocks in each cartridge so it looks like the CYAN is running low. Double check that you have a least 3 in each one and the error should go after a reboot. Please use the link below for any further problems or let me know.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8860),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8860,varset=prodName:Phaser%208860
Mar 20, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
1,551 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
