Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan wt200 won't start replaced all diaphrams spark ok cleaned gas filter
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. (THIS IS KEY!) Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
Starts ok. runs for several minutes, then dies and wont restart for 5 minutes
replace diaphrams in carby. clean or replace filter in tank on end of fuel line Ensure fuel cap allows ventilation for running.
Jan 20, 2013 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Poulan gas blower quit running - like it was out of gas - now it will not start
i have the same problem, first chech spark and clean exhaust, probably it works; if not, the problem is on the crankshaft, because it moves the time of ignition coil
Apr 18, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a weed eater trimmer that i replaced the gas lines but now when i pump the top of the carborator no gas gets to the carborator and the trimmer will not start.
REVERSE THE TWO FUEL LINES .. OTHER THINGS TO LOOK FORCHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Blower won't start and seems to flood out easily. Used it for one season and put away for winter. hasn't run since.
Needle seems to be stuck or thr diaphram is stiff and not closing off against the plate for the fuel
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
323 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
