Question about Sharp AL-1642CS Copier
Sharp AR-168D copies made are faded for about 2 inces from one side. Faxes coming in are fine.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; you need to clean scaner mirrow then should be OK.
Posted on Oct 02, 2009
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Sharp AR168D not printing
Look above the shelf where copies come out. If you see a disk about 1.5 to 2" across , it may have been bumped into the "locked" position.
Either turn it 90 degrees or take it out & throw it away.
Oct 02, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Drum replacement
open the right side door.open the front door.unscrew the devoloping unit lock screw. pull the unit out. pull drum unit out fromthe copier.
Feb 16, 2009 | Sharp AR-168D Copier
How to know if you need a new fuser unit
Your light is either a developer or a periodic maintenance indicator. Both are set to 25,000 copies. There is no indicator for the fuser which is rated at 50,000 copies (I find they fail any time after approx 35,000) The fuser will eventually not be able to keep itself clean causing dirty offset copies or jamming under the fuser picker fingers.There is no indicator for the drum . At 25,000 the drum and developer should be changed to maintain good copy quality. Whether your pm indicator lamp will shut down your machine is based on a service setting but since your past 25,000 it's probably set to not stop.
Jan 28, 2008 | Sharp AR-168D Copier
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
Nov 14, 2007 | Sharp AR-M455N Copier
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
