Question about Schumacher & Fast Charge Starter Charger
Should i remove battery from auto to charge - Schumacher & Fast Charge Starter Charger
  • 152 Answers
No not necessary- just hook up the red and black leads to the appropriate sides of the battery and leave on overnight.
Posted on Dec 01, 2009
Battery charged starter just clicking
  • Actually check batt voltage.. 12 -13 V
  • Check Batt cables.. remove them and clean them.
  • Check Alternator output.. 14V.. Is it getting to the battery? check battery while running engine.. should be receiving the 14+V Check it at the post.. not the outer edge of the cable.
  • Check Battery ground cable at chassis connection.. remove and clean..
  • Check Pos Cable at starter.. Remove and clean.
  • Last.. Remove starter and take to a Auto Zone or Oreilly Auto parts and let them check it for you.
Sep 07, 2014 | 2007 Ford F-150 Super
Battery hisses when charging battery
Is this battery the type that has the removable tops? If so, check the water level in each cell. Use distilled water to fill the cells to appropriate levels. Be careful of over-flow. Battery acid is very corrosive. Other considerations; battery is being over-charged, battery is worn and will not hold a charge. Auto Zone and Advance Auto will check/test a battery for you.
The negative wires go to ground. Has there been add-ons to the electrical system? Clean the Pos and Neg terminals and cables.
Apr 21, 2014 | 1994 Ford Ranger Supercab
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
Wont start charged battery cleaned termials , just clicks
I would double check the charge of the battery. You may have one or two dead cells which will decreace the battery voltage to where it will do what you say it is doing. Remove battery , take to Auto Zone or Advanced Auto and ask them to check charge and load. Sometimes batteries just go bad.
Please inform as to your progress. Good luck.
Jun 13, 2011 | Craftsman Garden
MY 1994 EXPLORER WAS SITTING AND HADN"T BEEN
remove battery and have it tested a your local auto parts store. Most auto parts stores like autozone or advance auto will test it for free. batterys will loose charge if they are old and have been sitting around for a period of time. If you have battery charger, set it up and put a low charge on it for 20 mins to a half hour. then try to start it again. If the battery is in good shape, check the cables to starter and ground. If that doesn't help you might have to remove the starter and have it tested.
Nov 16, 2010 | 1994 Ford Explorer Limited
Battery wont take charge
Check the battery for a dead cell. Even no maintenance batteries have caps that can be removed. Once removed, use a battery tester (<$5 most auto parts stores) to determine if there's a dead cell. If no dead cells exist, then the charging system aka alternator/regulator have issues. Before doing further analysis, ensure that the connections are tight and free of corrosion.
Dec 16, 2009 | Jaguar XKR Cars & Trucks
My 97 chevy blazer will not start when it is cooled out but if jumped off a nother car will start na
Sounds like a battery problem. Try removing the the battery terminals
cleaning then and charging the battery. Most auot part stores will ckeck
the battery and charging system for free. and if you buy a new battery they will install it for free. Advanced auto parts ,Autozone, O'Reilly's,Pep Boys And Wallmart Auto Offer Free instlation with a new battery purchse
Hope This Helps
Please leave feedback
Nov 16, 2009 | 1997 Chevrolet Blazer
Buying 95 honda civic. hasn't been used in 4 months. won't start up. any ideas? tried to charge battery. didn't work.
if battery was left uncharged the battery will go bad. suggest removing battery charge and take to auto store and have them test battery all major chain auto stores will test for free
Oct 30, 2009 | 1995 Honda Civic
My engine is makeing a clicking noise and not kicking over what to do?
Check battery connections that they are clean and tight.You can then jump it off and load test for free at Autozone
Oct 04, 2009 | 2004 Dodge Neon
1997 Deville ac compressor locked out - low
70 psi static does need a charge.find compressor relay, jump relay and compressor will start. add refrigerant,replace relay and a/c should work fine
Apr 16, 2009 | 1997 Cadillac Eldorado
Schumacher & Fast Charge Starter Charger  Logo
122 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
