Question about Dell Computers & Internet
My computer won't boot up - I either get the screen saying start in safe mode, or a Dell screen with little squilly blue lines. When I got it to come up once, then my mouse wouldn't move!
  • TigasTT May 11, 2010
    When you say the initial Dell screen, is that the black screen with the blue Dell logo? BTW what windows version do you have?
  • 380 Answers
That sounds like the main board has a failure. Your best option is contact Dell for a replacement system board. If your computer is no longer new, you can just purchase another used dell for about 100 bucks (Tower only) at gearxs or 3btech.net, or on google shopping. Before going that route though, contact Dell and have them assist you in diagnosing the issue. A replacement board is about 100-200 bucks, and will fit like a glove.
Posted on Oct 01, 2009
Inspiron zino HD won't boot up it just stays at the dell screen
Try booting into safe mode restart comp and its 1 of the f buttons f5 or something ea model number is different when in safe mode make sure you go to safe with networking and download new drivers of that doesn't work let me know ill walk u thru how to Chang the way you boot up your pc
Apr 03, 2013 | Computers & Internet
I have a dell optiplex 380 with windows xp on it and it froze on a light blue screen and all it had on it is the windows xp logo and says microsoft underneath it in the middle of the screen but a little to...
Restart the computer and Tap F8 to boot to safe mode. Once you see the options, then use the arrow keys to highlight safe mode and hit enter. Once you are inside safe mode, then do the system restore from there.
Click on start > programs > accessories > system tools > system restore
Select a restoration point and launch it.
If you can't go to safe mode, please drop me a line and I'll get back to you as soon as I can.
David
Mar 09, 2013 | Dell OptiPlex 380 PC Desktop
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
Dell will boot and freeze before reaching log in screen. Will only function in "Safe Mode". I have run all diagnostics and no problems detected. What could the problem be
There's some program or driver that is loading up when windows starts "normally" that's no when it starts in safe mode. Have you recently installed any new hardware? Webcam? Printer? Harddrive? if you have, go to device manager while in safe mode and remove the driver. If you installed a new program that runs automatically during start up, then use MSCONFIG to change it from starting. Again, do this from safe mode. Go to start > run >TYPE: msconfig and then ok, and then the tab should be called "startup". one of these two things are most likely the problem because like you said it boots in safe mode no problem, Safe mode had the computer boot with only the bare minimum drivers/software needed for start up. If neither of these two things work, then, (again, in safe mode) right click your hard drive from My computer > properties >Tools > Check now (under error checking)
Hope this helps you solve it
Sep 21, 2009 | Dell Inspiron 1525 Laptop
Won' start up properly
Hello, you might be having an issue with a Peripheral Device in the computer, conflicting with it to boot up, please disconnect any USB devices, port replicators, or printers/scanner on the serial ports, if this solves the issue and you're able to access your computer, please reinstall the drivers for those devices, you can test each one of them to see wich one is the troublemaker.
Additionally if you don't have any peripherals connected, then please try to boot up in safe mode, to do so, please restart the computer, then when you see the Dell Logo, press the F8 key at start up, then please chose the safe mode option, and press enter. If you are able to enter safe mode, then please press the keys [Windows] + [R] and in the screen that pops up, type "msconfig", without quotes, go to the Startup tap and select, disable all. Afterwars restart the computer and let us know if it worked.
Apr 30, 2009 | Dell Inspiron 1501 Notebook
Problem with windows. It won't boot up
this only problem with windows or virus....
you can use recovery to solve this problem..nothing else...check and it will work fine
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Dell 1501 inspiron laptop blank screen
Have you installed any application/program prior to the blue screen? Most blue screen causes your system not to boot to your operating system anymore. It is possible that your hard drive is crashed due to a virus infections or spywares. Incompatibility and corrupted system registry may affect your system to have blue screen as well.
You may try the following steps below.
1. Restart your computer. After you pressed the power button to restart. Keep on tapping F8 key on the keyboard on and off.
2. Boot advanced option will show up on the screen. You may boot your computer to the following option.
a. Last known good configuration
b. Safe mode with Networking.
If Safe mode w/networking works, restore your computer to an earlier using the system restore features.
Keep me posted.
Regards,
jeff
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
65 people viewed this question
Alun Cox
