Question about Acer Computers & Internet
I need a ps 5221 -06 - Acer Computers & Internet
  • 380 Answers
Contact the manufacturer or search Google shopping to buy one.
Posted on Oct 01, 2009
5 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: need to replace a Lite-on power supply
Yes, I see what you mean since your computer is an SFF, (Small Form Factor), and uses an SFF power supply. Hard to get a power supply replacement, much less the power switch for the power supply.
Some things to note about working on a personal computer power supply,
1.They use Electrolytic Capacitors inside them. The aluminum case, cylindrical looking objects. These 'Caps' are designed to slowly build up a charge, then release it all at once. They can hold a charge after being disconnected from power, for weeks, sometimes Months!
There are typically two large ones used in the Input Stage. These hold a LARGE charge! Touching the terminals on the bottom of a capacitor, or touching a circuit that they are in, can result in a bad shock, or even Fatal one!
2.The particular power supply you have, has a Soft Power On function built in. There is no switch cable from the front panel of the computer, to the power supply. The power supply can be plugged into power constantly, and needs no On/Off switch on the back. This switch could be removed, and the wires to it soldered together, with heat shrink tubing over the connection.
http://en.wikipedia.org/wiki/Computer_power_supply
http://en.wikipedia.org/wiki/Switched-mode_power_supply
You DON'T need an On/Off switch on the power supply.
I have given you a solution in the form of information, but am NOT recommending you open your power supply, Nor work on it.
Posted on Jul 22, 2009
joecoolvette
  • 5660 Answers
SOURCE: replacing the power supply on my acer pc. Liteon
Yes,
https://www.pacificgeek.com/product.asp?ID=846862&C=304&S=-1
It's made by Delta for Acer. Model Number is
DPS-220UB A
I know you didn't ask for this information, but I feel compelled to tell you.
I know it's hard finding the right style/shape of power supply to fit in your computer case,.
BUT,
the above power supply is a cheap quality power supply. Anything in power supplies made by Delta is.
(Plus it seems to be the only thing available)
I wish you would consider buying a decent, economical, ATX computer case, and put the hardware components out of your Acer into it.
The reasoning is,
1) There will be more airflow. Airflow, is used to keep the hardware components inside the computer cool.
This increases the lifespan of the hardware components.
2) An ATX style of power supply can be used. The style that approximately 90 percent of personal computers, out there use.
You could buy a power supply for the same amount of money, that would be more Reliable, have more Power, run Quieter due to a larger fan, and has higher quality components inside.
3) Should you wish to add additional harddrives, and optical drives in the future, there will be room.
Posted on Feb 16, 2010
Testimonial: "Thanks a lot!!!"
SOURCE: I need a schematic for a LITE-ON PS-5221-06
Try to get ahold of Lite-On's customer service. Here is a link so that you can enter all of you information, send it in, and wait till you get a respons: http://www.liteon.com/Services.aspx?id=2ca6d4cd-8a57-4b27-b98a-748be8c0c80f
Posted on Mar 03, 2010
  • 104 Answers
SOURCE: i want to purchase of LITE ON smps model PS 5221 06 AT BANGALORE
Your best best would be to order it online. I found 3 on ebay that is willing to ship to your country. As for local dealers I am not sure. Hope this helps.
Posted on May 27, 2010
Steering wheel hard to turn, what should I check for this?
Heavy steering (not caused by neglected low tyre pressures) is usually related to a problem or failure with the power steering pump system.
Items to check on the Power Steering (PS) System
1. Is the serpentine belt slipping on the power steering pump pulley because it is old and worn and needs to be replaced? If it is slipping it will likely be slipping on other pulleys also.
2. You have allowed the power steering fluid to run low and the PS pump is starved and is sucking air. Running the fluid low will damage the PS pump and the steering rack. Low fluid in the PS reservoir is normally a sign of a fluid leak in the system. A leak could be on a system hose, in the PS pump or in the steering rack.
3. The PS pump may have failed, hence cannot produce the required pressure in the PS system, and needs to be replaced.
Oct 27, 2015 | Cars & Trucks
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
How do you movie gmail.com
Use the forgot password feature on the logon page and follow instructions.
Mar 01, 2015 | gmail.com
Canon ir2520 don't print PS files. The PS driver is installed.
Did you buy the option for PS. It may be loaded, but PS is owned by Adobe and you need to buy the rights to use them
Jun 02, 2011 | Canon PCL Printer Kit-AF1 - 2860B001
I am wanting to connect a Gateway keyboard to a Dell PC but I need an adapter from female to male usb port. What adapter do I need? Will I need to download any software for this?
amm udont need an adapter, the keyboard once usb will plug right in,, if its circular,means its a ps2 port and you need ps2 to usb. No no drivers needed. Or usb to ps2 ,, depends on your needs, But all Usb are standarad stuff.
May 06, 2011 | Dell Computers & Internet
I need to know where is the oil presure switch of a 2003 ford windstar 3.8l
On a 1996 3.8 L Should be under the power steering on the block. Looking at the pulleys on the right side just above the oil pan. This would involve removing the pwr steering punp and hoses.
I don't know if a 2003 is different.. You could inspect the area visually to check it.
To get to replace it...
96 - 98 windstar 3.8 oil pressure switch is located under power steering pump. Remove serpentine belt and alternator. Remove PS pump pulley with special puller to get access to PS pump bolts. Drain PS pump and remove PS hoses. Remove PS pump.
Nov 30, 2010 | 2000 Ford Windstar
Driver for PS/2 compatible mouse for tower PC HP compaq dx7300 were not found and not installed in my PC.
PS/2 compatible mouse drivers are generic drivers already install when the Operating System to your PC. You don't need any extra PS/2 drivers!! "
Check your mousePS/2 pins & PS/2 socket -> Pins..Dented..Broken?
Mouse could be faulty. Try replacing another PS/2 mouse to your PC.
If the PS/2 socket is faulty, you can use a USB mouse too.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Computers & Internet
Can we play play station games on our pc computer without remort controller?
You will need the controller to play PS games on the PC.
As well as that you will need a PS emulator and drivers + a patch to make the PS controller work. The only PS controler that will work is a USB PS3 controller.
If you use a standard USB game pad you find that you can't play the games properly.
You can get an emulator by clicking on the link below >>>>>>
http://www.emulator-zone.com/doc.php/psx/
Regards.
May 27, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Tower Will not turn on.
Blinking yellow/amber light indicates PS not operating within specs. You can look at replacing the PS but might need to find out if something else caused the PS problem, such as other components caused the PS to overheat, etc. Were you having any problems with any of the drives? Strange noises etc?
Aug 04, 2008 | Dell XPS 200 PC Desktop
Faulty ps/2 connections
Without know what computer you have, you should be able to go into setup (BIOS) and set the mouse to "none".  It should start.
Oct 25, 2007 | Microsoft Multimedia Internet Keyboard...
Computers & Internet Logo
194 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
