Question about Pyle PLA4340 Car Audio Amplifier
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
  • 655 Answers
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Posted on Oct 03, 2009
I want to wire my 4 ohm DVC subs to my Pyle 3000 watt home receiver amp
No you don't. You'll fry the amp. You need a low frequency processor to strip the mid and hi frequencies out of the signal applied to the subs or you'll have a full frequency sub that will sound cruddy. If your amp outputs 8 ohms the you'll have to wire 2 speakers in series or poof goes the amp. If the amp is only 16 ohms then you're out of luck unless you have 2 more speakers to connect in series to the 2 you aleady have.
Feb 19, 2015 | Pyle Car Audio & Video
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
I have a pyle 1000w 2 channel amp.just got it last week. last night driving home, stops working. protection light stays on. when i checked it, it was hot. so im assuming the thermal protection kicked on....
keep it in a vented area dont ever cover it position it were nothing will block it.it sounds like it does not have a fan so they sell those fans that you sit your laptop on.they cost about 10 bucks and wire it to your amp remote and ground inputs and it should help it stay cool....
May 24, 2010 | Pyle Car Audio & Video
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
I have two kicker l5 10's with a 1600 DB SERIES bass dont sound very clear how can i make it clear and loud ?
Make sure to tune the amp according to the subs. Turn all the levels down on the amp, then start with turning up the gain till you can tell the sub is struggling, from there turn up the crossover to around 120hz. Then adjust the gain again as now it will prolly be to high. Also it depends on how you have the subs wired up.
Apr 06, 2009 | Kicker Solo-Baric L5 Car Subwoofer
My sub/amp doesn't work.
it is most likely a bad ground, that should do it
Mar 18, 2009 | Legacy Audio LA370 Car Audio Amplifier
I have a Pyle PLD3MU head unit and a sony XM-ZR1252 amp (2 channel) and the car has 2 door speakers, 2 rear deck speakers, and 2 12" subs. What is the best configuration to hook this up?
Run your 12" subs off the amp make sure to Xover for bass only.
Try running the 4 speakers direct to the stereo may not be enough power, Might have to invest in another amp and speaker upgrade to get it sounding just right.
But its a place to start.
Jan 07, 2009 | Pyle PLDVIN7 Car DVD Player
Treble come out with lowpass filter on
get it fix but sounds like a low current problem check cable connections
Jan 10, 2007 | Pyle PLA1485R Car Audio Amplifier
Pyle PLA4340 Car Audio Amplifier Logo
161 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
