Question about Dewalt DC925 Cordless Drill
How to select hammer action - Dewalt DC925 Cordless Drill
  • 61 Answers
Turn the torque adjustment collar until the hammer is selected (there is a picture of a hammer instead of a number there)
Posted on Oct 27, 2009
What parts should I have beforehand if my Makita HP1640 has stopped hammering.The hammer switch seems to work and engage but little or no hammer action.
Here is the parts breakdown of your drill. It is hard to say exactly what is the problem, but #10, #13, and #17 have to do with the hammer action. #15 is the hammer switch. It also could be bad. good luck on that. https://www.ereplacementparts.com/makita-hp1640-5834-hammer-drill-parts-c-97_16247_40066.html
Jan 14, 2017 | Makita Drills
When hammer or hammer drill action is selected hammer action is not working
The ring of the impact bolt in front inside the locking sleeve where the chisel is driven on can be blocked (also broken part ) but not to see until you remove the parts .
Jan 11, 2016 | Hammer Drills
Demolition hammer model D25889 will not hammer motor turns on but not hammering
check the position of the operation lever
it should have 3 positions drill, hammer drill and hammer
make sure it is fully selected or the hammer action will not engage
Dec 31, 2015 | Hammering
How sds drill differ from ordinary rotatary drill .what are main basic feature of sds hammer drill
The difference is the working action. SDS drills use a corrugated cams running against each other.
May 30, 2012 | Drills
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
Sep 27, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
I have a bosch 24v gbh vre drill ive changed the brushs the drill has no hammer action your help whould be very helpfull many thanks andy
Check that the ramped discs and the selector lever for the hammer action are assembled correctly. The lever should push the chuck shaft clear of the hammer action discs or release the shaft so that it can move inwards to allow the ramps to ride up each other.
Feb 02, 2011 | Garden
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
Can u tell me is it better to use diamand core bit using hammer action or rotary only
Diamond core bit works great on either setting, you will get faster results on the hammer action though
Jan 02, 2010 | Hitachi Dv18dl 18v Hxp 3.0 Ah Hammer Drill
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Hammer Drills differnces
Hammer Drills combine the rotation of a regular drill with a pounding action. These two actions enable the hammer drill to bore holes in masonry quickly without burning the bit.
Aug 27, 2008 | Dewalt DC2PAKCA Heavy Duty Xrp 18V...
Dewalt DC925 Cordless Drill Logo
95 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
