Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
I can not start my PC. It does have a green
I can not start my PC. It does have a green light in the back of the PC.
I check all connections in the PC, made sure that the electric plug was working (Lap light test).
This is the second HP (Pc) that died in 5 years.
I went last week and got ASUS PC (Love it), I would like to fix the alder PC anyway.
Any ideas?
Thanks
  • 380 Answers
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Posted on Oct 01, 2009
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
No sign of life from the display half but the bottom reads life.
If you have already checked the connections from the screen to the PC, check that you have a power light on the screen. (Green or Amber). If no light, check power to screen. If it is amber, then the screen is not getting a signal from the PC - recheck connections. I would suggest you try and connect the pc to a different monitor to check whether it is the screen or the PC.
If it is the same on another Monitor or if the power button is green on the screen, then the pc is not sending information properly. Turn the pc off manually by holding the power button on the bottom half for about 10 seconds. All lights should go off from it. Now turn it back on again and see what happens.
If you see loading windows and then goes black, do the following:
Turn off the pc (bottom half). Turn back on and as soon as you pressed the button to turn on, start tapping the F8 key until you come to "Windows Advanced options" screen. use the arrow keys and go to Enable VGA mode. Press the return key twice. If it loads to windows, then fine. If not, then you may have a problem with the display adapter.
Hope that helps
Nov 11, 2010 | Computers & Internet
Power supply green light flashes and computer won't turn on
hi
if your getting power ligh then chack disply setting from Bios still you have prob then just chack you HDD and Processor
May 30, 2010 | HP Pavilion a800n (PP163AA) PC Desktop
My pc wont turn on but the green power light in back is on why wont it start up
Check the cable connecting your monitor and video card, see if this is secure and not loose.
May 26, 2010 | HP Media Center m7250n (ED842AA) PC...
I moved my computer. Hooked it back up and now the side speakers do not work. They power on but no sound . tried several connections. USB is plugged in and the green to green connection is in. checked all...
Hi
Please can you advise if you have 2 sound cards installed
You will know this by looking at the back of the computer, the sound card wil have 3 ports coloured Purple/Dark Green and Light green
Your speaker connection needs to go into the light green and will have a symbol above it like this ))(left arrow)
If there are 2 sets of ports then try one and if that fails try the other if there is only one plug your speaker conneciton into the light green port
Regards
Jan 31, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
No response from desk top computer when trying to turn it on.
I think your SMPS has gone bad. Get it checked from a qualified person
Dec 13, 2008 | HP Pavilion a450n PC Desktop
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer starts and stops within seconds but batt light is solid green and pluged in
Ensure That your Power button is clicking back and staying connected - this would cause the computer to shut down immediately.
Feb 04, 2008 | Sharp Actius AL27 Notebook
Computers & Internet Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
