Question about Uniden BC350 Base Scanner
I have a uniden bearcat portable and base I cant figure out how to program it
    President:
  • 2,761 Answers
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Posted on Jan 02, 2010
I have a uniden bearcat trunktracker 3
If you have Adobe Acrobat reader, you should be able to view the manual at the following link:
http://www.uniden.com/pdf/BCT8om.pdf
Hope this helps! Good luck!
Sep 15, 2009 | Uniden BCT8 Base Scanner
How to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Jul 31, 2009 | Uniden BCT8 Base Scanner
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
How to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
Jan 19, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Old bearcat 250 ---how to program it
http://www.uniden.com/index/manuals_results.cfm?cat=3
download your model numers manual from uniden , pick your model from the list . it will guide you thru programming .
Dec 21, 2008 | Uniden BC248CLT Base Scanner
Uniden BC350 Base Scanner Logo
151 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
