Question about Dell Inspiron 1525 Laptop
My Inspiron 1525 does not recognize the memory I added. It had 3GB, I removed the 1GB and added a 2GB. When it did not register the additional memory, I put the old one back in and it now does not recognize it either. I think when I put in the new one, when it booted up and said the memory configuration has changed and gave me some options, I chose the wrong one. Please help!
  • 3,940 Answers
Once you change the ram, you have to boot to the system setup so that the BIOS can recognize the new module.
When inserting the ram module in the slot, it should be at a 30 degree angle to the system and inserted till the golden contacts can not be seen looking straight down at the slot. Then press the module down until the retention clips click. The top edge of the contacts should then be barely visible.
Once the RAM has been properly inserted, then boot to the system setup, exit then boot to windows
Posted on Oct 01, 2009
Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
According to Panasonic's Toughbook CFT8
owners manual there is only one slot where
you can add extra RAM. The other memory
is "non-removable" and probably soldered
directly to the motherboard.
I double checked on the Kingston RAM Website:
Bank Schema: 1GB Standard:
[1GB] (Non-Removable)
or
3GB Standard:
or
2GB Standard:
[2GB] (Non-Removable)
or
3GB Standard:
Sorry to disappoint you but that is how they
made the CFT8 Toughbook.
If it is any consolation, the CFC1 and CFC2 both have
two (2) slots on the underside of the unit. Not the CFT8.
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 17, 2014 | Panasonic Toughbook Cf-t8 Win7 Core2 Duo...
I added an additional 1GB of RAM card , but my computer will not recognize the additional memory. I tried swapping cards between the two slots , nothing . The specs say the motherboard can handle 1GB per...
If you have the additonal memory in the system correctly, it should be recognized.
Attempt to boot the system with just the new stick in. If it boots you most likely have a motherboard issue. If it doesn't, it's just a bad stick of memory and I suggest just getting a new one.
Mar 05, 2011 | E-Machines W6409 (7234) PC Desktop
I added a new ram before it has a 1GB and now i added another 2GB of ram.when i turn on my laptop it says there installed memory is 3GB which is right,but the problem it says also that 1GB usable..its that...
assuming your running th correct memory modules(same clock speed and size) you ahould have more useable. switch the larger one out to the nexxt slot and see if that fixes it. if not then just use the 2 gb by itself. this is more than enough for windows 7
Jan 19, 2011 | Compaq Presario M2000 Notebook
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
Removed 1gb memeory and installed 2gb but only 2gb recognized
You may need to go to your manufacturer's website for toshiba, and flash your bios with the latest flash for this.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jun 30, 2009 | Lenovo T7200 Notebook
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Sony Vaio computer not recognizing added RAM
First, do you have a 32-bit or 64-bit operating system. Unless you have the latter, you will only see 3GB maximum.
Second, did you look at the Sony specs (you didn't say what model you have)? Chances are your Sony maxes out at 2GB.
Apr 14, 2009 | Sony Computers & Internet
SYSTEM DOESN'T RECOGNIZE NEW MEMORY MODULE
Memory modules must be the correct type and speed, and be within the specifications for the laptop. Just because it fits in the slot doesn't mean it will work.
The Dell inspiron B130 has 2 slots. Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. if you tried to insert a 2GB module, it will not work.
If the module is within these parameters, remove and re-seat the memory, and try swapping the modules from one slot to the other. It may be a bad slot.
Dec 28, 2008 | Dell Inspiron B130 Notebook
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
Dell Inspiron 1525 Laptop Logo
156 people viewed this question
Alun Cox
