Question about Sony Cyber-Shot DSC-T5 Digital Camera
The camera can not take pictures and stop suddenly and always appears on the screen this phase Rein the "Memory stick" when i open the camera
  • 641 Answers
SOURCE: memory stick error
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Posted on Sep 04, 2007
SOURCE: No CF card
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
Posted on May 09, 2008
  • 74 Answers
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Posted on Aug 12, 2008
  • 74 Answers
SOURCE: Sony Memory Stick ProDuo Memory Problem
if you insert it into your pc and go to my computer right click on the icon for the drive that contains the stick select format and then follow the steps this should solve your problem.
Posted on Oct 17, 2008
welcomejee
  • 10594 Answers
SOURCE: Format Error keeps coming up when I try to take a picture
You need to format memory stick by going into camera menu.
Click Sony Support to download user manual of DSC-S700
Posted on Mar 18, 2009
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
Camera not working
The word ACCESS appears in the LCD and the digital camera does not respond. Solution
sp.gif sp.gif If the camera appears to freeze or lock and the word ACCESS is displayed in the LCD, then a problem has occurred during the reading or writing of data on the Memory Stick® media. This could be caused by the media, or the camera itself.
Follow the steps below to troubleshoot this issue.
  1. Perform a power reset on the camera.
  2. If the issue is not resolved, turn off the camera.
  3. Remove the Memory Stick® media from the camera.
  4. Clean the metal contacts on the Memory Stick media with a soft, dry cloth or clean pencil eraser.
  5. Reinsert the Memory Stick media into the camera.
  6. Turn on the camera.
  7. If the issue reoccurs, turn off the camera.
  8. Remove the Memory Stick media from the camera.
  9. Insert a different Memory Stick media.
  10. Turn on the camera. NOTE: If the issue does not occur with different Memory Stick media, the previous Memory Stick media may be faulty and should be discarded.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C267279
Jul 23, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have had my sony for about 2 years and suddenly last night while shooting pictures, the message "unable to format card" appeared on my screen - what can I do?
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Pics from Cyber Shot DSC-W55 Are not loading to Computer.
does the removable drive appear in ''my computer'' ?
when i plug my camera in it doesnt always popup asking you to open to view.
Mar 09, 2009 | Dell Dimension 3000 PC Desktop
Transferring photo from computer to memory stick
Many cameras will not let you write to the card. Try using a card reader, which will make the memory card appear to the computer as a separate hard drive.
Nov 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
"No Memory Stick" error (but I never had one!)
W don't you just get a memory stick for it? Then you don't have to "write off your $300 camera as a total loss"
Dec 25, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Sony Cyber-Shot DSC-T5 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
