Kodak m863 shuts down when i press the zoom button
It started by shutting down immediately after starting up. Then it randomly started powering on and staying on, but when i try to zoom in it shuts down.
To reset your MacBook's battery and settings, you can try the following steps:
Resetting the System Management Controller (SMC): a. Shut down your MacBook. b. Press and hold the Shift + Control + Option keys on the left side of the keyboard and the power button at the same time for 10 seconds. c. Release all the keys and the power button at the same time, then press the power button again to turn on your MacBook.
Resetting the NVRAM (non-volatile random-access memory): a. Shut down your MacBook. b. Press the power button to turn on your MacBook, then immediately press and hold the Command + Option + P + R keys. c. Keep holding the keys until you hear the startup sound twice. d. Release the keys and let your MacBook start up normally.
Calibrating your MacBook battery: a. Charge your MacBook battery to 100%. b. Use your MacBook until the battery runs out of power and your MacBook shuts down. c. Leave your MacBook off and unplugged for at least 5 hours. d. Connect your MacBook to the power adapter and charge it to 100%.
These steps should help reset your MacBook's battery and settings.
Thank you speters9971- it worked. However, what worked for my c315 is unplugging it and then plugging and then pressing the power and and cancel button at the same time until it turned off and then turned on again. This reset it. Thanks again,
Press the MENU button. Use left/right-arrow to select the Capture tab (the camera icon without the "+" sign). Use up/down-arrow to select "Date Stamp" and press the OK button. Select "Off" and press OK.
Everytime you removed the battery of your camera, date and time will be reset. You have to set the date and time correctly.
Follow the steps below.
1.Press the Menu button. 2.select the Setup Tab, it has camera w/ tool icon 3.Scroll down until you select Date and Time 4.Press Ok then set the date and time.
