Question about Whirlpool Dryers
Dryer won't heat?
I have a whirlpool dryer model # WED5840SW0. It wont heat up. i have tested the voltage, it checks, replaced the heating element, the internal bias thermostat and the high limit thermostat and still no heat!! i check the fuse and it works. i am at a loss!! please help!!!
  • Whirlpool Master
  • 7,482 Answers
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Posted on Oct 01, 2009
What shoudl I check to determine why my whirlpool WED5840SW0 is not heating?
Check the thermal fuse the cutout fuse & all thermostats .
Also check the heating element & check to see if it is touching any metal. It also could be the centrifical switch in the motor.
Hope this helps
May 09, 2014 | Dryers
Whirlpool Dryer IED4400SQ0 wont get hot
Did you pull the element out and test it? I think it is your heating element. Visually inspecting is never enough. Just hook it up to high voltage independently to ensure it heats. It will turn red hot.
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
    check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
    Mar 11, 2012 | Whirlpool Dryers
    Brand new dryer wont heat
    depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
    Feb 17, 2012 | Roper Dryers
    My tumble dryers not drying my clothes, i've had it coming up 6 years
    Proper Voltage
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Jan 22, 2010 | Whirlpool LER5636P Electric Dryer
    Wont heat up
    Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
    Jan 22, 2010 | Dryers
    Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
    Hello there
    Here is a list of item for you to check Hope this is very helpful for you
    Best regards Richard
    My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
    Proper Voltage
    Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Dryers Logo
    221 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
