Question about Sony KP-51WS500 51" Rear Projection Television
Projection Lamps Does Anyone know where I can get a new green projection lamp for my KP-57WV600. The product was discontinued and Sony No Longer Carries the part. I have looked everywhere
    President:
  • 4,402 Answers
Have you call sony direct?
Sony received reports of flickering on select rear projection TV models and immediately started an investigation. Sony's engineering team found that in a small percentage of sets (less than 1%) made with impregnated cathode CRTs, the material used to impregnate the cathode may attach itself to another section of the electron gun and cause a mild brightness fluctuation or change in hue.
Once this problem was diagnosed, Sony published a Service Fix for this issue and authorized Sony Service Centers and Authorized Service Centers to make modifications and replace all 3 CRTs in affected units at no cost to the consumer in order to resolve the issue. In addition, a change to the manufacturing line was made to ensure that current units do not experiencethis problem.
If a consumer is experiencing this symptom, contact Sony Call Center (800-222-SONY) to schedule a service call. Sony has extended the warranty on these models for this issue and is working with authorized service centers, providing all current information for the repair as well as assisting them in ordering the parts beforehand, so the repair can be
completed in one call.
replacement tube can be purchased here
http://www.mcmconnect.com/lampsandmounts/catalog/search.do;jsessionid=C8463FCF1BF9E7E924ECF2F1182C7529?searchtext=SONY
Posted on Dec 20, 2007
Rear Projection HDTV-Ready Television and help with Sony KP-57WV600 57 in. ... still have sound, does this mean the projection lamp gone bad? When you turn on the TV, you can see a unclear image for few...
with this type of tv, you can be almost certain that something has gone wrong with the lamp or the cooling system for the lamp. the cost associated with these kinds of fixes are usually more than the unit is worth. The life span on rear projection TV's is not all that good,5-10 years. some last longer. but for most this is a good estimate. this tv has an auto focus feature that might help. also if this TV has a SD slot for upgrades, give it a try as well.
Apr 29, 2010 | Sony KP-57WV600 57" Rear Projection...
Sony Projection TV problem
sony rear projection KP series are know for having bad utbes after while..ihad seen the blue tube goes on most.
Jan 22, 2010 | Sony KP-57WV600 57" Rear Projection...
SONY KP-61V75 PROJECTION LAMPS
you should be able to find replacements at the following link and leaving a email at their contact us link and list your model and what you need they respond quickly.
http://servicemanuals.vstore.ca/
May 16, 2009 | Sony KP-61V75 61" Rear Projection...
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Mar 15, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Sony goes blue
you need a new Blue CRT you can get them at the following link.
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
Sep 24, 2008 | Sony KP-57WV600 57" Rear Projection...
Replacement lamp/bulb sony kp-61hs10
that model number doesn't use lamps it uses cathode ray tubes projection tubes. the CRTs for that tv are probably no longer available.
Feb 22, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
