Question about Toaster Ovens
Bush toaster is blowing fuses when switched on
    Problem Solver:
  • 14 Answers
It appears that there is a short in the toaster somewhere. Many times it is the cord. See if you can remove the cord and then test to see if the two leads of the cord are shorted with an ohmeter.
Bob Janelli
Posted on Oct 01, 2009
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Euro pro to241r
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Oct 10, 2013 | Toaster Ovens
Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
Jan 01, 2013 | Oster Toaster Ovens
I had a house with old funky wiring. I'm pretty sure it caused me to blow a fuse in my toaster oven. Can you tell me where the fuse is located?
The manual mentions nothing about any user serviceable fuse or reset. "Funky" wiring in your home shouldn't cause an appliance to fail. Wiring that is in poor condition usually results in blown fuses or tripped circuit breakers in the service panel, heat in places it shouldn't happen and of course, fires.
It is very possible that the outlet is worn to the point that it doesn't make very good contact with the toaster's plug and has caused the toaster to fail to heat up. Try removing the toaster to a different outlet and try again. Check the original outlet with another appliance or lamp, etc. to see if it works or not. Also, check to be sure any ground fault outlet hasn't tripped.
If the toaster fails to work as expected in another outlet, there's little you can do to repair without jeopardizing your safety - especially if you're not familiar with appliance repair. These appliances aren't really meant for disassembly - manufacturers don't want to be liable for "repairs" that end with injuries, burns and death so the make them pretty hard to take apart. Even if you are successful, they make even harder to reassemble without it looking obvious that it has been disassembled.
Take it apart if you want - learn about how it works and buy a new one. These devices don't rely on rocket science and the controls are pretty simple - but it is an electrical device and electricity isn't a hobby. Be safe. Be smart.
BTW - I don't want your money - I just don't want you to get hurt.
Goiod luck!
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
No broiler heat
its not a diode its a fuse a high temp fuse . there is a number on it with a "c" after it thats the temp it opens ..... you can jump it out with a small bare wire just to test your elements and thermostat . if the thermostat does not cycle this fuse will blow . do not leave it jumped out , this is just for testing . find one on line with the number . and high temp fuse ... good luck
Feb 05, 2009 | GE 168947 Toaster Oven with Convection...
4 slice toaster blows fuse when toaster uses 4 burners
You will need to move it to a different outlet that is not on the circuit that you are using or just toast 2 slices at a time.
May 06, 2008 | Toastmaster 328 Toaster Oven with...
Toaster Ovens Logo
56 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
