Question about Food Mixers
Mixer makes grinding noise on settings 1@3 - Food Mixers
  • jlbrooks33 Oct 02, 2009
    Thanks. Are special tools required to access the gear box and to remove gears?
    Novelist:
  • 149 Answers
Hello. A bearing in the motor is the likely culprit. Is the mixer under warranty? If so, replace it immediately. If not, check for a local appliance repair shop nearby. When the mixer runs at higher speeds, the ball-bearings can "skip" over flat areas and run smoother. There might be a problem with the gears meshing together improperly. At the slower speeds, any play between the teeth surfaces becomes more noticeable.--Hope I helped you.
Posted on Oct 02, 2009
  • 3,741 Answers
ok as per the problem which you have mentioned that motor is faulty.but as you clearly mentioned that it only makes noise on setting 1 and 3.this clears that motor is proper.in the base of the mixer in both the inner and the outer side there are gears and brushes.that are got cracked so its making noise on particular settings and not in particular settings.get that gears replaced. ------------------ this will help.thank you for using fixya.keep updated.please do rate the solution.thanks.
Posted on Oct 01, 2009
  • 274 Answers
SOURCE: Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Posted on Oct 23, 2007
  • 45 Answers
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
ricardok45
  • 135 Answers
SOURCE: Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 44 Answers
SOURCE: my mixer made a grinding noise, so i oiled it
I am assuming that when you oiled it you merely squirted oil in various places without actually taking the mixer apart. You probably did a good thing if....if....it corrects the grinding noise...but...oil is not only an excellent lubricant it is also a very good insulator and if you got oil into the switch area where it turns on then you may have got oil inside and it can be insulating the place where electrical contact is made. For a possible quickie solution you might try to use something to eliminate the oil that may have got into the switch. Best thing is probably to go to Radio Shack and buy their contact cleaner spray can and use it on the switch. That stuff is real expensive though. A cheaper solution might be to use isopropol alcohol if you have some handy or even spray carburetor cleaner as both of them will completely dry quickly. Be sure to unplug the unit before doing this and allow it to completely dry before plugging back in. You can do all of this without taking anything apart. If it then runs ok then I suspect the grinding noise is still there as the gears inside probably need a little grease. If you want to go that trouble you can remove screws and open the case up...carefully...and put a dab of auto wheel bearing grease on your finger and rub it into the area where the gear teeth are. Do not use a big gob of it ... just a little amount is all needed. If you do not have any grease handy you can use vasline if you have some in the house. If the mixer did not turn on after the above dousing of alcohol etc. from the outside then you may need to do the cleaning directly on it from inside...so if you do take the mixer apart spray the cleaner directly inside the switch. When you take the mixer apart do not remove the shaft/motor/armature or other parts...remove only the cover and enough to do the repair. The possible problem is that if you take it apart too much it will be difficult to get back together particularly if you remove the armature and contact area of the commutator where the carbon brushes are. While inside there though look at the copper commutator area where the tiny carbon brushes make electrical contact. They may be pitted or not allowing the brushes to make good connection. To correct this you can spray contact cleaner directly onto the contact area to clean it. Let it dry and reassemble and the mixer should run ok. If the mixer is very old and been used a lot then the contact area of the commutator may be worn so badly that it does not make good contact with the brushes or the brushes may be worn down so much that they no longer make good contact. In that case you would need to actually remove the armature assembly...what I told you not to do above if you are not too good at reassembling things. Once the armature is removed it is easy to take some fine grit sandpaper and clean the copper commutator making it clean and bright copper color like new again. Also if the carbon brushes are almost totally worn down you probably can find some new ones that will fit ok by taking the old ones to your local hardware store as many of them stock carbon brushes nowadays. If you do all this and are able to reassemble the mixer then it should be just about as good as new again. Hopefully you do not need to go to all the trouble of the major disassembly though. Good luck.
Posted on Aug 22, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchenaid mixer motor makes loud grinding,
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Posted on Nov 03, 2009
Grinding sounds
The case screws can come loose and grind on the planetary. To see if that's the problem you need to pop the chrome drip ring off that covers part of the planetary. It's just a push fit, pop off with screwdriver tapped with a hammer.
Feb 06, 2016 | KitchenAid Food Mixers
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
Oct 17, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
The motor is making a grinding noise. The mixer still works, it just sounds weird.
I have fixed many mixers with the same problem. The only part that consistently wears out
is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out
and becoming chipped. The grinding noises you hear are made by the Worm Gear and the
Follower. As time goes on, the metal filings from the damaged follower will eventually destroy the Follower and the Planetary will stop rotating.
Sooner or later that gear need to be replaced. Also remember to use new Grease after
a new gear replacement (metal filings from the old gear will damage your new gear)
Apr 02, 2011 | KitchenAid KP2671 Professional 6 Series...
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Hobart mixer making grinding noise
the noise is not a good sign. would rec. taking apart trans. and investigate gears,shafts, before futher damage takes place
Nov 30, 2009 | Hobart D340-6009 Mixer
Kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
Dec 13, 2007 | KitchenAid K45SS Classic Stand Mixer
Grinding Noise
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
67 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
