Question about Imperial ICVD-1-H Turbo-Flow Gas Single Oven
ICVG convection oven shut down during cooking process
I have a stacked imperial commercial oven (new) that when in operation the two sets of ovens will shutdown. Let them cool and you can re-start without a problem. Nothing trips I would assume that a hi-temp limit is tripped and resets? There is plenty of ventilation and a exhaust hood. What do you think?
  • 833 Answers
Wrench, clearly something is causing them to do what they do. Best I can give you are thinking points.
Does this happen every time?
Is there something else on the circuit that could cause undervoltage?
If the hi temp is tripping, why? Put a thermometer in the oven and see where it is.
Get the factory guy on the phone.
Posted on Dec 21, 2007
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
I have a imperial convection oven that I just purschase and operated fore 4 days, and the fan stoped working any idei what would cause this?
You don't say what model. Some Imperial ovens have a cool-down switch that lets the fan run with the doors open but not in cook mode. That is a starting point.
Mar 27, 2012 | Imperial Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
I put in a new switch for the top oven but the convection fan is going on only in cool down mode not on oven mode. it should go on when oven turns on (button up) but goes on when button clicks down (cool...
Door needs to be closed in cook mode to work. You sure you put the switch in the right way up? Also you could have a dodgy door switch as the cook/cool switch and the door switch operate as a two-way circuit.
Nov 20, 2010 | Imperial ICV-2-H Turbo-Flow Electric...
How do you unlock the door to a convection oven?
Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
Nov 18, 2009 | Kenmore Ovens
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
Best way to clean it?
hi..first unplug the oven,take equal portion of lime juice
and vinegar,mix it well,take a soft cloth,dip in the solution
mixed and clean the interior as well as the exterior of the
micro wave.
try this out..
thank u..
rate me..
May 04, 2009 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Imperial ICVD-1-H Turbo-Flow Gas Single Oven Logo
415 people viewed this question
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
John Rodgers
John Rodgers
Are you an Imperial Oven Expert? Answer questions, earn points and help others
