Question about Samsung SGH-D600 Cellular Phone
When i go in to any of the menus it asks for a pass word but i dont now it
Unlock passcode motorola droid x
If it's asking for the pass code it should eventually ask for your Gmail info and they have ways you can recover the login info if unknown. However once the pass code is set the only way to get past it other than what I've already mentioned is a factory reset.
Mar 15, 2014 | Cell Phones
Mitsubishi WS55315 rear-projection has gone dark
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Mar 24, 2012 | Mitsubishi WS-65315 65" Rear Projection...
V-chip block passcode
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Mar 17, 2011 | Mitsubishi WD-62525 62" Rear Projection...
EM227 ASKS FOR PASS CODE ..I DONT HAVE WHY?
The pass code should be 0000 but if you get it synced. It will not stay connected. Its not your htc phone. I went to HTC's website to get the bluetooth update, installed it, and im still having the same problems. Its the piece of s#*% em227 bluetooth that is the problem. Your best solution is to go and buy a new bluetooth cause yours, just like mines, wont work. Have A Nice Day
Sep 26, 2009 | Southern Telecom Emerson Bluetooth Headset...
I dont know how to scan of my Lexmark x7350
Assuming the Lexxy software drivers are properly installed you simply load up whatever software you want to scan into (paint shop, word etc...) and import from the scanner. Depending on the software you will use either the "import from..." or "acquire" menus items (look through the menus of the particular software you are using). You will get a submenu asking for the source. From this you select "scanner" or "twain". This will invoke your scanner software and from there you follow the prompts.
Sep 14, 2009 | Lexmark X7350 InkJet Printer
Pass word
if you dont know the bios password then bring it to a computer store to have the CMOS cleared.
Mar 26, 2009 | Dell Inspiron 2200 Notebook
Parental pin
Hi!
To unlock your set requires two steps: the first is to get past the lock screen.To do that, press the QV( or previous channel?) and 9 buttons at the same time when you are asked to enter your lock code.
Now that you're past the lock screen, find the menu that covers locking and unlocking. QV/9 (previous channel/9) is a one-time bypass; if you turn the set off, it'll be locked again when you turn it on, so you first need to LOCK it again, with a pass code you can remember (try 1,1,1,1). Once you lock it, you can exit from all the menus, then try to change inputs. It'll ask for a pass code, which you now know!
Please ask for further clarifications and rate the solution as Fixya if found useful.
Thanks
Rylee
Mar 14, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Toshiba wrc1000
Try entering "admin" for the user and "password" for the password.
Mar 31, 2008 | Toshiba WRC-1000 Router (PA3227C1ETC)
Bluetooth pass key
yes... the default is "0000". :)
- J.
Feb 21, 2008 | RIM BlackBerry 7290
Samsung SGH-D600 Cellular Phone Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
