Question about Electrical Supplies
No voltage at breakers on either side. Checked output of voltage reg..had nothing replaced voltage reg still nothing. Any suggestions Generac model 09734-1 ser 1946771
  • 8,404 Answers
If you have no voltage on the buss bar ... you will not have any on the back side of the breaker.
The first thing you must do it get power running into the panel.
When the panel is hot, now you can prove or disprove voltage at the back side of the breaker.
I can tell you from experience, if you have a hot panel and your breaker is not passing power and there are ants around, that you will not get power. Ants love to move into the housing of a nice warm breaker. The only fix for this is replace the breaker.
But, as I said, you got to get power to the panel first.
Let me know what happens
a
Posted on Oct 06, 2009
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Generac 40kw single phase generator starter engages after 30sec of running
    For the over voltage there is an adjustment on the control board.
    Should be tested with a load something plugged in.
    The hertz might just come on when under load and adjusted too.
    If you need more give a model number and whether it is 13kw or 40kw.
    May 05, 2013 | Generac 13,000 Watt / 13,000 Watt Home...
    Generac generator
    have you checked the coil in motor iyself?
    Mar 11, 2012 | Measuring Tools & Sensors
    No output from my generator
    check breaker, your outlets should be like a gfi
    May 21, 2009 | Coleman Powermate Premium Plus 6250W...
    Generac portable generator doesn't produce power
    Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
    May 15, 2009 | Electrical Supplies
    Generac model # 09734-1 no voltage output. would like a manual
    Flash the fields. Remove front cover from the generator end. You will see the brushes and rings on the rotor. The ring closest to you is positive and the ring closest to the rotor windings is negative. With a 12 volt batttery and the generator running, place the positive side of the battery to the ring towards you and negative to the back ring. Make sure to use jumpers and keep fingers away from rotating parts and don't get zapped. You should see output voltage increase. If it does, your voltage regulator is bad, if it doesn't your generator end is bad.
    Apr 14, 2009 | Generac 5341 30A Manual 4-circuit Transfer...
    No voltage output
    It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
    Apr 02, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
    Electrical Supplies Logo
    660 people viewed this question
    Top Electrical Supplies Experts
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
