Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Looking for the location of the lamp an dhow to remove?
  • 115 Answers
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
Dubai Dhow Cruise | Dhow Cruise Dinner Dubai
what problem are you facing with website..??
Sep 09, 2013 | Computers & Internet
The `power botton flashes and the screen remains dark
The model number/brand indicated here (if wrong let me know) is a DLP set---means it uses a lamp---lamp is suspect number one.
Lamp is customer replaceable and easy to change--if you locate it and remove it-(it has a screw or two and a handle--cartridge with lamp pulls out) it is a good idea also to look at the color wheel -the lamp faces the wheel--if wheel is shattered or missing pieces it is the problem.
You are when pull lamp out looking to see if it is shattered inside--do not touch face of lamp with your hand and of course have set off and unplugged when you do this.
If the lamp--Google the model number with "lamp" and you will find dozens of sellers.
If the wheel is bad--do same to locate and You Tube has video instructions for replacing it---average people can do the repair themselves.
color wheel
4_25_2012_2_52_05_pm.jpgTypical lamp cartridge (not yours but similar)
SD TECH
Apr 25, 2012 | Samsung HLP4674W 46" Rear Projection HDTV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
How do I change my projection lamp for my Sony Wega KDF 50E2000.
Hello.
You have to get lamp fully assembled for easy replacement. That mean lamp should be purchased already installed in black plastic housing.
If you stand behind of your TV set on the left hand side (actual side) of your TV you will locate lamp door cover with latch on the top of it. Just push the latch down and remove cover. Deeper inside you will locate black plastic lamp door with handle that you have to rotate 1/8 of the turn counter-clockwise to open it up ( like a submarine style thing). Pull it out and next thing that you will discover - lamp assembly itself. Put your index finger inside of the ring-looking latch, pull it up and out. You have lamp removed now. Extremely carefully install new lamp in same order making sure that new lamp is ALL WAY IN (there is safety switch that sense if lamp is not properly in) and install the door making sure it is ALL WAY IN and LOCKED (there is another safety switch that sense it). If any of the switches will not sense proper installation TV WILL NOT turn on.
You can turn TV on to check if it is working. Last thing to do - reinstall lamp door cover.
Russ.
Dec 01, 2010 | Sony KDF-50E2000 50" HDTV
I have a Delongi Microwave combi and need to locate the lamp, the model is AC930AMQ, so far I cannot see the lamp anywhere and need to replace it. If it is internal I have no prblem with that as I am an...
I removed the outer case by three posidrive screws and two security screws. The lamp is located in a downward position on the left hand side looking from the back. A normal 25watt 300c ses bulb is suitable so no need to buy original if you don't want to. Take care before removing cover by unplugging the unit and only work on the lamp area as there is high voltage present charged in the capacitors !
Oct 17, 2009 | DeLonghi Microwave Ovens
How remove the Sony Rear Projection TV KDS-R50XBR1
the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Where is the battery located?
The battery is located under the cover immediately behind the Head lamp assembly <DRIVER side> remove the three screws that secure the cover and push the 4 tabs on the heat sink looking with the cords running from it. you can now remove this larger cover to reveal the battery
Aug 09, 2009 | 2005 Chevrolet Equinox
How do you change a headlight bulb on a 04 ram 2500 4x4
There are 3 bolts two which are located on front of the lamp housing and one more which is located under the lamp housing (if looking at the left side it is above the front bumper trim the space between the two), then remove the two plastic screws for the lamp housing gasket. When you have removed all hardware then pull hard on the head lamp you will have to pull pretty hard then it will pop out your new bulb will be a 9007.
Jul 16, 2009 | 2006 Dodge Ram 2500
Where is the battery located in the Equinox?
You find the battery under the cover located behind head lamp assembly, on the driver side. Remove the three screws that secure the cover and push the four tabs on the heat sink looking with the cords running from it. Then remove the larger cover to reveal the battery.
Aug 08, 2008 | 2005 Chevrolet Equinox
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
