Question about Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan
I have 21 ceiling fans in my house.
I have 21 of the ceiling fans shown in the picture above in my house.The remote code have 16 possibility. I have some of them with the same remote code. Any solutions?
  • Jonah Musto Oct 03, 2009
    I have set 2 fans in 1 room to the same remote code, and now, the fans in different room have the different remote code. Thank you.
  • Samuel Charles Spriggs May 11, 2010
    Some thots: You could set the 6 fans which are the furthest distance apart on the same frequency -- no guarantee that would work. If some of these are in the same room you could set them on the same frequency. You could aslo put different brand receivers & remotes in some of them if you verify that the frequencies are different.--------- Charlie Charlie
    President:
  • 1,187 Answers
Three suggestions (maybe not viable solutions):
1. Consider creating ceiling fan "groups". A group is a set of fans that is controlled by one remote.
Group: All (or some) in all vaulted ceilings.
Group: All hallways
Group: Outdoor celing fans
2.
Power OFF ceiling fans at the wall switch that are not used often. Those can have duplicate codes.
3.
If the remote controls are iR (infrared) rather than RF (Radio frequency), then the ceiling fans that are farthest apart or have more solid walls in between, can have the same codes and not be affected by the "wrong" remote.
Posted on Oct 01, 2009
Testimonial: "Cro-mag rally registration code: AMAHFJDHFMAM"
    New Friend:
  • 45 Answers
Setting two fans to the same code in a room works, until one fan turns on and the other didn't receive the signal, now their out of sinc. It sounds like you have the older 4-dipswitch 64-bit "red-light" system. There is a new 8-dipswitch 256-bit "green light" system that you could install on just a few of your fans to ease the frequency jam on your red-light system and finally get control of all your fans individually. I believe they run about $60 for the transmitter and receiver together and you can purchase them at Fan Man Lighting 1-866-600-3267. They have 30 years experience and will know your problem right off.
Posted on Oct 17, 2009
Need code for Concord ceiling fans
You have this backwards. The code is stored in the remote. The receiver is located inside the fan housing. You can try removing batteries from the remote, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries (or installing new ones) and testing operation. If no results, disconnect power at the ceiling fan source, not the fan itself. Pause briefly, reconnect power and test operation.
Sep 02, 2014 | Concord Fans Dryers
What is the code for the remote control to work the fan I accidently changed the 5 series code in the remote
You will have to look in your fan to find the dip switch for the receiver, depending on your model, it may be in the canopy at the ceiling, or in the switch housing where the light is, or possibly in the fan housing itself. Look your model# up and reply here and I can help you better.
Thanks
Sep 21, 2010 | Hunter 52" Ceiling Fan With Light And...
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Ceiling fan lights & fan come on without using remote
on some you set a code in the remote control ..then you teach that code to the control unit ..on others you have to set dip switches on the remote control and on the fan to match .. some of the units have dip switches on the top of the fan motor housing ..some have code setting switches on the control unit located inside the fan .. at any rate the fan and remote have to have matching codes ..
here is some information on some units
http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
sometimes the switches are set correctly but the contacts get dirty .. so on the remote, behind the batteries is the code switches .. you can operate each one a few times to clean them ... remember where they are set ... set them back that way unless you are going to change the switches on the module in the fan ... you can check your neighbors remote to see if its on the same setting .. if so one of you has to change dip switch settings on both the fan and remote.. on some older units the code is fixed on the receiver in the fan .. the code is marked on its box .. that code has to be set into the remote unit and is not adjustable ..
this might be the mfg for the hampton bay fans ..it might be a little help
http://www.kingoffans.com/#/products/FAQ
Jun 05, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Light comes on without pressing remote button
You either have a faulty remote/reciever, or you are getting interference from some other electrical device. before you change the remote/reciever try changing the frequency on the remote and the receiver. You will have a set of dip switches or jumper blocks on posts in the battery compartment of your remote and on your receiver inside the decorative canopy cover against the ceiling (sometimes the receiver is built into the motor housing and can be seen from above the motor without opening an access) just make sure the code you use is the same on the remote and the receiver
Sep 07, 2009 | Hunter 52" Ceiling Fan With Light And...
I bought a house with hunter remote control 52" fans, and one doesn't work, I replaced the battery and still doesn't work. How can I verify the remote code is correct for this fan? The code on the fan is...
set the remote to match the fan code. be sure you have a good battery in the remote and in thereceiver which is in the dish at the ceiling holding the electrical wires
Jun 23, 2009 | Hunter 52" Ceiling Fan With Light And...
I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Nov 12, 2008 | Universal Remote Control Hampton Bay...
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Aug 07, 2008 | Casablanca Fan Televison & Video
Fan stops working for days
hi,
sounds like theres some sort of radio interference in your house, you can try to change the code for the fan, turn off the breaker at the fuse box then in the canopy above the fan near the ceiling is the dip switch for the fan, you have to remove that cover near the ceiling and look for a tiny set of switches and change the position of them , also in the remote you have to take the batteries out and change that code in the remote so it matches the new code you set in the canopy. if it still does it you can try to unplug all of your cordless phones and wireless routers in the house, anything that you have with an antenna and turn it off and unplug those to see if that helps the situation.
good luck
J
Jul 18, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Ceiling fan remote not working
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Jun 16, 2008 | Hunter 52" Ceiling Fan With Light And...
Sea Gull Lighting 1555-734 Three-Light Cypress Grecian Stone Ceiling Fan Logo
171 people viewed this question
Top Sea Gull Lighting Dryers Experts
Are you a Sea Gull Lighting Dryer Expert? Answer questions, earn points and help others
