Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 253.56953601 freezer isnt working properly. food is slowly thawing and ice maker stopped working
  • 612 Answers
I think you have a defrost problem. Look at the inside lower back panel of your freezer. If I'm correct, you will see ice built up. You can take the panel out, defrost with a blow dryer. (After defrosting you can check your heaters. I'm sure you have a bad heater) You can put panel back in and turn the unit back on. It will run ok for around 3 days, This will give you time to repair or get repaired without loosing you food.
Please rate solution
Posted on Oct 02, 2009
  • James Hilton
    James Hilton Oct 02, 2009
    I meant to add. There is nothing wrong with you ice maker. It's doing just what it's designed to do. The reason the ice maker stopped is because it has a thermostat inside it. This cuts it off when it's not cold enough so the it will not cycle over and over and the water does not continue to fill each time. It it did, it would end up flooding your freezer. Good luck
5 Suggested Answers
  • 1073 Answers
SOURCE: Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Posted on May 11, 2008
Sea Breeze
  • 4654 Answers
SOURCE: We have a Kenmore Model#363.9552410 that is a side
Most likely your defrost timer is defective. Located inside the fresh food section and inside a metal box behind the control panel. Turn the timer slowly clockwise until compressor stops. Wait 30 minutes or until compressor restarts If the compressor does not restart turn again until it starts during this time the freezer should be in defrost and sounds of crackling or sizzling is normal. Let me know what you find. The part number for your defrost timer WR9X489
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Posted on Jun 28, 2009
SOURCE: Ice maker not working. Kenmore Elite with bottom
Ice maker making continuous clicking sounds after several day power outage.
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: The freezer is warming, ice maker is not working.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Auto-defrost refrigerator freezer ice build-up
Check vents/grills to make sure they are dust free. May need to be replaced. In meantime, leave freezer door open to thaw away ice (remove food not wanting to get thawed)
Mar 06, 2014 | Kenmore Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
We have a Kenmore Model#363.9552410 that is a side by side with ice maker inside. We noticed the back wall of the freezer was completely frosted over and no ice was being made. We turned off the whole...
Thanks, Sea Breeze
Jun 28, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Area between the doors on the side by side are really hot.
Hi!!! the door was left open some forgot to close the door..if you have more problems let us know..Good luck..
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
Kenmore fridge isnt working
check in the rear of the unit u will need to pull it out and remove the panel see if the fan (Condenser) is running is the compresser running?? is the compresser hottt?? do you hear a hum and then a click noise?? is the condenser dirty?? remove the front kick plate to see this.. After you have cked these things let me know and we can go from there
Feb 16, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
221 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
