Question about Sharp Office Equipment & Supplies
H5-01 code what is a H5-01 service code on a sharp ar-c260?
  • 63 Answers
First thing H5 means you've had 5 continues jams at or before your fuser unit. So the first thing you need to do is make sure you all your paper out of the machine and double check the fuser unit for paper as well as the transfer belt unit for paper on it or behind it. You can simply remove it by first removing your fuser unit (lock is under fuser, a turn dial) then pull the transfer belt out and tilt up. **** Warning**** use caution when removing belt as to not damage the unit. After you do all this you will need to reset the code.
Press the buttons in the following order :
#/P key (program) - Asterisk (*) key -CLEAR key -
Asterisk (*) key - Ready for input of a main code of simulation
Type 14 with the key pad then press your copy key
Press execute then YES Once done press the CA key on the panel and the machine will restart.
Posted on Oct 12, 2009
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
I need the driver 4 sharp ar-c260 scanner driver
Has scanning been turned on with the product key? Is your Image Send button working? If so you can go to the web page and set up a scan to a network drive folder. Or buy Sharpdesk v.3.2 with the network scanner tool.
Aug 12, 2010 | Sharp AR-C260M All-In-One Printer
What does the code H4-00 on a Sharp AR-C260 copier mean?
That is a heat error and easy to clear.
On your machine press P * C *. That is the #*C*.
The machine will enter diagnostics. In the small box enter the number 14 and press start, It will then give you an option to press the number 1 to clear the fault.
Once there, enter 1, then press start. Press clear a couple of times and the machine will reset and run.
You could have a fuser problem. But I would say 95 percent of the time doing the P*C* will resolve it.
Mar 21, 2010 | Sharp AR-C260M All-In-One Printer
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
MANUAL FOR SHARP ARC270
Here's a link to the manuals download page at Sharp:
http://www.sharpusa.com/products/TypeManuals/0,1083,18,00.html
They don't list an AR-C270, but a C260 is listed. Maybe it will give you some help. You can also try contacting their customer service through the site if you still need more information
Feb 18, 2009 | Sharp AR-C270 Color Copier
SHARP AR 651 SERVICE CALL
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
346 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
