Question about Kenmore 800 7983 Dryer
Gas will not stay lit on my Kenmore series 80 dryer..
Model number is 110.7683250. I have replaced the igniter but don't know what else to do.. Please help
    President:
  • 1,776 Answers
If the ignitor is working properly (glowing visibly) and the burner will not light, then I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit gas flow to the burner. If faulty the gas valves will not open and the burner cannot light. It is recommended that if any are suspected of being faulty, that both (all) be changed at the same time and they will likely come from the parts supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 01, 2009
5 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Posted on Oct 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Posted on Mar 05, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • 351 Answers
SOURCE: Kenmore 80 series dryer makes a constant squeaking
could be rollers, idler, belt or motor, we have to tear it apart and manually move things to find out... simply visit my site and call if you need help whirlpoolpartssurplus.com mark
Posted on Jun 25, 2009
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Dec 08, 2009 | Kenmore Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Mar 05, 2009 | Kenmore 800 7982 Dryer
No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Mar 03, 2009 | Kenmore Dryers
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 800 7983 Dryer Logo
387 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
