Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My kenmore fridge/freezer has food thawing on the freezer side. also the ice maker is no longer working. any help? model #253.56953601
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
  • 1073 Answers
SOURCE: Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Posted on May 11, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
  • 531 Answers
SOURCE: Amana SXD 22S2W -Frost on fins but not cooling.
you may have aburn out may be heater
Posted on Mar 31, 2009
aasc
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
Why isn't my frigidaire ice maker working?
Hello Lynn, thank you for your post!
I understand that your Frigidaire refrigerator is not making ice and items inside of the freezer are thawing out. This could be an issue with your control panel or sealed system, is there anything being displaying on the front of your refrigerator? May I also have your model number? You can locate your serial tag (which lists your model number) on the right hand wall of the fresh food side. With that information I would be able to assist you further. -Matt
Apr 19, 2016 | Frigidaire Refrigerators
Why is the freezer not freezing and why is the ice maker making any ice?
I suggest that if you call a service representative and have someone come service your appliance.
May 12, 2017 | Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Freezer thawed, fridge warmed
The compressor is short cycling, or not starting. being purchaced in 2004, the compressor may be under a 5 year part and labor warranty with SEARS ...BUT GOOD LUCK!!!. Find ur receipt and warranty. read carefully and hold them to it.. empty it and unplug to be safe
Aug 25, 2009 | Kenmore Refrigerators
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
GC2224gek admiral freezer keeps defrosting and the food thaws. The fridge is working. Switch it off for a day and fridge, freezer and ice maker works. After a few days it starts defrosting and I noticed it...
Mar 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Area between the doors on the side by side are really hot.
Hi!!! the door was left open some forgot to close the door..if you have more problems let us know..Good luck..
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerator and Freezer not cooling....
  1. my kenmore side by side Model #465825 Refrigerator doesn't cool or and ice maker is'nt making ice.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
