Question about Insignia LCDTV26 26 in. Television
TV has an annoying high pitched whistle sound that is constant afer about 3 minutes of being on???? If you slighlty tilt the TV with your hand it goes away but you can't wedge anything under it to make it stop
Fan making high pitched whistle
check for debris in the air intake. I've had leaves in mine make a similar noise
Nov 14, 2016 | Cars & Trucks
Whistling when TV is switched on. LG LCD 32''
If the sound is coming from the back of the TV, then the issue is with the power supply and may get worse causing the TV not to power on.
If the sound is coming from the speakers, then the issue may be with the main board, an audio hookup to the TV, and or a bad ground loop with the TV and the connections to it.
May 17, 2010 | LG 32LG30 32 in. LCD HDTV
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
High pitched sound
you can fix this if you are very careful. it is call a high voltage leak. inside of the tv, close to where the power comes in will be what is called a high voltage transformer. if you are electrically inclined, unplug the tv, take the back off and then hook the power line up and turn the tv on. with the lights off in the room and a flashlight handy, look at where the sound is coming from. locate where the sound is coming from and look very carefully(very carefull not to touch with your hands or head to any part) for a white-ish blue arc of electricity. if you can see this then that is where the problem is. to fix it you will need to put something in between the two places that it is arcing from. a piece of plastic or silicon putty or anything non-conductive will work. again, be very careful or you might get the dogsnot shocked out you.
Jan 06, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Insignia LCDTV26 26 in. Television Logo
193 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
