Question about Cerwin Vega CLSC-12S Subwoofer
Is my amp kaput? (CLSC-12S Cerwin Vega 12 inch 300 watt sub)
Is my amp kaput? For some reason my sub just quit working one day but at closer look I noticed that the speaker was still working but it was so faint you couldn't hear it, only feel it. If the amp is bad is there somewhere I can buy a replacement amp or should I rely on a local electronic repairman here in my town to take a peek see?
Thanks !!!
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
Anyone know where I can find a replacement woofer for a Cerwin Vega HT-S12A? It is a 12 inch woofer...The cabinet and amp are in great shape however a stupid kid came over and cranked the sub and seems to...
  • Sounds like the speaker coil to me.
  • Yours is a a 150 watt, 12" subwoofer. If I were you I would not knock my head on the table looking for a Cerwin Vega to put into there. You can a far better quality one for a reasonable price. This Pioneer here.
http://www.google.com/products/catalog?q=12%22+woofer&hl=en&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=1600&bih=799&um=1&ie=UTF-8&cid=5529109873222407637&sa=X&ei=glO6TamAB-L00gGzvKmNAQ&ved=0CLoBEPMCMAM# I
  • I don't see that Amp blowing this speaker and it averages about $75. Just turn the box on it's side and remove the screws holding the speaker in place. Drop the speaker. Remove connectors and revers to finis the job.
Regards,
Tony
Apr 29, 2011 | Cerwin Vega HTS12A Subwoofer
Thanks and regards
Stelios
Jun 13, 2010 | Cerwin Vega CLSC-12S Subwoofer
When playing on high volume the treble dissapear. I have a 2.6kw Cerwin amp. And Clsc 215 speakers. No bi- wire on my speakers. When I lower the volume the treble returnes. What is wrong???
Sounds like your overpowering the horns and the circuit breaker is tripping to prevent them from blowing. You are running more power then they can handle. You can turn down the volume or will have to purchase higher wattage horns...
Mar 24, 2010 | Cerwin Vega Cerwin-Vega CLSC-215 3-Way...
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Will a 300 rms amp power a cerwin vega vmax 124?
Hello dustin_stewa,
300 watts RMS is a little on the low side, but it'll power the sub. The sub is rated for 500 watts RMS.
If you haven't already purchased the amp, I'd recommend considering one with a little more output, perhaps in the range of 400-600 watts RMS.
Hope this helps.
Oct 19, 2009 | MTX X Thunder 300XD Car Amp
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Hits the brown note too often....
I recommend wearing these.
Alternatively, install a high-pass filter into the signal path to remove anything below 20Hz.
Apr 25, 2009 | Cerwin Vega CLSC-12S Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Cerwin Vega CLSC-12S Subwoofer Logo
154 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
