Question about Seiko Smart Label Printer 100 Thermal
Get error when saving address - Seiko Smart Label Printer 100 Thermal
Address book
Where's the address file located. You need to have full rights (Read, Write, File Scan, Modify, Delete, etc) to the Address file. Right-click on the file name, select Properties, view the rights you have to the file.
Apr 14, 2014 | Dymo LabelWriter 400 Thermal Printer
What does address error mean
it has gone out of bounce... out of code while was looking for
another link. due... to it's dirty, it's already erased or has not
the address was looking. mostly because it's not well placed or the program like "saved" is erased, altered.
Feb 23, 2014 | Sega Genesis 2 Console
I originally quoted my email address as matthew.duffin4@talktalk.net whereas the 4 was an error and my email address is matthew.duffin@talktalk.netIsmy account open in the correct email address?
Since you managed to post this question, your FixYa account is definitely open.
To change your email address, click your username in the upper-right corner, click "My Profile", click the "My Account" tab, edit the email field, then click the "Save My Information" button.
Aug 02, 2013 | GPS
I get "Send Error (SMTP)"
It took me a while to figure this out. Your 3220 must be connected to ethernet (I havent tried it with the 3220 connected directly to the computer). Also, this works with a free email with domain Godaddy account, so YMMV.
1. Open your web browser and navigate to the 3220's CentreWare IS. 2. Click on "Protocol/SMTP Server" 3. Check "Host Name" 4. Type smtpout.secureserver.net/80 for server/port 5. Check "SMTP requires authentication" 6. Enter your username/pw 7. Click "Save Changes"
If you are asked for a username/pw to save the settings, the 3220's default are admin/1111.
Now click on "E-mail/E-mail Setup" on the navigation. Make sure your default [From:] address is your sender email address (they must match). Click "Save Changes"
As a final recommendation, I strongly suggest that you create your address book (E-mal/Local Address Book on the navigation) to make it easier to send by email, otherwise you will have to manually enter email addresses using the 3220's keypad (very slow!). Create groups for sending scans to several emails without having to select each individual email from the 3220's panel (also slow!).
Hope this helps.
Dec 31, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
Can not hook-up to web. error 8001000B
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.158.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Read more: http://www.ps3news.com/forums/ps3-guides-tutorials/how-fix-wireless-internet-error-8001000b-ps3-98772.html#ixzz1FxUHQxte
Hope this helps. Please Rate
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
Everytime I turn on my camera it says : Turn the power off and on again. It flashed the error E or F 91:01.
It sounds like you have a FLASH FAIL error message on a Sony Cybershot.
This solution was provided by acem77 at agorarequestdotcom:
1st I ordered the service manual from http://servicemanuals.net/index.html
2nd I downloaded a RM95 emulator program. this program actslike/replaces the remote commander sony techs use to change settings.
http://stanza.techfocus.net/camera/rm95.zip in side the zip is the RM95EMUL.EXE and RM95DUMP.EXE
3rd I made the LanC Interface Cable on this web site http://www.hardwareanalysis.com/action/printarticle/1464
the steps above save you $200 in service tools. The cable parts cost about $12 the manual cost about $30.
I can sell you a cd copy cheaper if you have the same camera.
when you are ready plug the cable you made into the (ext flash) or (lanC) port on the sony camera.
Put your camera in play mode and turn it on. Then start the RM95DUMP.EXE program in a dos prompt.
Type (RM95DUMP.EXE>factory.txt) this will save a copy of all the setting of the camera to your pc.
Now you did that run RM95EMUL.EXE.
You will need the service manual to know what settings to change.
I had to change these addresses to unlock page d with the flash error setting.
Set address to (reset all values to default after page d is changed and saved)
Page: 0 .address: 01,and set data: 01.
Page: 2 .address: 03,and set data: 00.
Page: 2 .address: 00,and set data: 2d.
Page: 2 .address: 01,and set data: 2d.
Page: 2 .address: 02,and set data: 01.
Cant change this setting until you change the above settings
Page: d .address: 67,and set data: 00 (if you have an error this will be 4 set it back to 0)
Write/save the new change to memory
Jul 16, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
MAC ADDRESS
- You have to set the Mac Address value after exchange PCB Assy.
(only Bluetooth product)
1. Disassemble the YP-T10 case and Find the MAC Address. (12 digit)
2. Open “memo pad” and write Mac Address on it.
3. Save “BDADDR”
4. Connecting USB, Copy “BDADDR” into Root.
5. To confirm Bluetooth Mac Address
- Power on
- “Setting – My Device Info – View the MAC Address”
6. If an error occurs, the address of the error is saved in
the ErrorMac .txt file as text
7. Mac Address Setting is done.
Dec 12, 2008 | Samsung YP-T10 Digital Media Player
MS Outlook Contacts error solution
completely uninstall and download ccleaner from downloads.com. run it which removes any previous office system related files. then reinstall office
Jun 06, 2008 | Microsoft Office Outlook 2003 for PC
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Seiko Smart Label Printer 100 Thermal Logo
18 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
