Question about KitchenAid Food Mixers
Bowl is crooked the arms on the sides hold it at an angle
My bowl lift lever on the hobart (bought off ebay) K5ss doesnt lock the bowl into place. What do I need to do to fix it, or at least figure out whats wrong if something needs to be replaced.
On a bowl lift mixer there is a small metal clip on the back of the bowl support arm, it works in conjunction with a small "NIB" on the back of the bowl, when you put the bowl on the support arm there are two pins that the bowl rests on, on each side of the support arm, you place the bowl on the pins then press down the rear of the bowl untill the nib locks into the clip, if the bowl is not locking in place then one of four things are wrong, one of the pins are not on the support arm, the NIB on the back of the bowl has come off (it is spot welded on) or the clip at the yolk of the support arm has worn down or broke in half and there would be no locking action without it. The pins or the clip are inexpensive if it is the Nib on the back of the bowl you will need a new bowl. Hope that helps if not pleases get back with us so we can FiXya.
Oct 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Were is the screw located to rise or lower attectments
I can answer the question but I need to know which model mixer you have?
Oct 10, 2014 | Food Mixers
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I have the KitchenAid 5 Qt HD Professional stand mixer. When I securely attached the bowl to the bowl support arms (I hear the bowl click to the back) and use it to knead bread (the flour amount well...
hello step ..... yes. You may have to adjust the height of the bowl a wee bit as it sounds like the dough hook is hitting the side of the bowl..
It tells the steps in your manual.
Easy to do.
If you don't have the manual you can download it for free here http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Joe
Mar 12, 2011 | KitchenAid K5AWH Stand Mixer
My h 600 will only run when i hold the start button as soon as i let go it stops
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
Jun 09, 2010 | Hobart H600 Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
I can't get the bowl onto my KitchenAid Pro mixer
Hi. I'll give you the cheap/fast solution first. Get a 2-3 ft. section of metal pipe that will fit over the bent arm, gradually, incrementaly and slowly bend the arm out using the pipe. check it at each increment for fit and level.
Now for the more expensive/slow solution. Find the nearest Kitchenaid "approved" repair service store. You will then be looking at a replacement bowl support and the labour to repair it. Be prepared to wait for up to a month for Kitchenaid to fill the parts order. If you find that these solutions have assisted you, please rate them. Good luck! ricardok45
Mar 03, 2009 | KitchenAid KSM50PR Professional Series...
Kitchenaid Pro 6 Bowl Support bent?
Hi. Your mixer should still be under warranty. Call Kitchenaid Customer Service and tell them your story. If you tell them that you tried to fix it by spreading the arms, your warranty will be deemed void. Kitchenaid is usually very good at replacing under warranty. If you found this solution helpfull, pleas rate it Good luck! ricardok45
Jan 10, 2009 | KitchenAid KP2671 Professional 6 Series...
Need to change the part that holds the bowl on an 80 qt mixer...
Look behind the slides there should be 5 bolts on each side,you may have to scrap because there painted over.From the front remove the stainlees splash guard,you will see a big screw.Remove the 2 bolts in the plate,support the yoke with a block off wood and remove.
Dec 01, 2008 | Hobart Food Mixers
Food Mixers Logo
65 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
