Plugged in, not charging
My lg R500 notebook, just died on me while running on the battery (without any warning whatsoever). When restarted, with cable cord connected, the indicator in the toolbar says "0% available (plugged in, not charging)". --> I must now have the cable cord connected all the time for the computer to run.
I've tried to clean the battery, start without the battery in place, uninstall/reinstall the MS ACPI-Compliant Control Method Battery.
None of the above has worked?!
Help much appreciated!
Running on vista.
  • 615 Answers
Laptops has something called hibernations and that works when you have a low battery it will backup your computer to the point that you lost use of the battery and if you get shutout the computer should recover in many occasions this does not work and as result you get a large file at your hard disk that consuming very large section on your hard drive and may take the whole drive and also may effect the battery. Now see if you can turn this feature off and go to your driver (cJ and delete the large file that created at the time you lost use of your computer. Recheck your battery again but you need to check and see if the cable good as in some occasions it looks ok but does not charge … see what will happen then we can go to the next step, remind you that we can not see any information that passed between you and other techs....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Posted on Oct 01, 2009
My Lenovo thinkpad R500 shuts down without warning
Check over temperature. Is the air way clear of dust and fluff? Is the fan and radiator clear of fluff?
Aug 20, 2016 | Lenovo ThinkPad R500 Notebook
RESTART LG COMPUTER
I have the same problem, but no solution. have you tried a new power cord?
Nov 01, 2012 | LG X110 series (610074350750)
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
Computer just died.. no lights whatsoever. power
Take out the battery and try to start from the charger - if it's the same then you had a major hardware failure , most likely your motherboard has died. You need to take it to a repair shop for a precise diagnose and repair.
Jul 31, 2010 | Toshiba Satellite A215-S7422 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
No power whatsoever, but...
Try taking the battery out and running the laptop with just the AC adapter.
Also you should use a multimeter to test your AC adapter for voltage. If there is voltage from your AC adapter and the unit will not turn on with the battery removed then you have a faulty motherboard or another component in the laptop.
If it works without the battery all you need to get is a new battery or live with it without battery.
Sep 16, 2008 | Computers & Internet
Laptop won't turn on
anyway firstly check removing the battery and plug to a well functioning socket to power supply and test it yourself if it works and if it doesnt then post to me what happen after that and again does it brings light to know if it sees the battery at all if it sees the battery then try charging it for hours ok .
Aug 04, 2008 | Sony VAIO VGN-S460 Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
506 people viewed this question
David Payne
David Payne
