Question about Wharfedale DVD-M3 DVD Player
We have a digital tv which we retuned, but cant do it to the recorder. When u switch it on nothing comes on.
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Posted on Oct 03, 2009
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
Samsung lcd tv problems
TV IS OK RETUNE THE SET TUNUNG CABLE CHANALS DIGITAL AND ANALOGUE IT IS ON SET UP MANU
Sep 07, 2014 | Samsung Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I cant retune my proline tv/dvd combo as there is no retuning option in the limited menu.no option to reset on the controller either so have no signal now since swithover.how can i get it to reset anyone?
Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
Oct 20, 2010 | Televison & Video
I cant seem to record on to my VCR but have no trouble playing old videos,is this because the VCR is old and therefore not digital? Retuning the TV with a box was no problem.
In order to record from the tv onto vhs, it is required that you have a tv signal coming straight to the vcr. If your converter box is plugged into the tv alone then the vcr won't record. To fix this, try plugging your converter box directly into the vcr, instead, and then plug the vcr into the tv. You may have to retune the channels. Good luck!
Apr 07, 2010 | Panasonic Televison & Video
SINCE RETUNING TV IN dECEMBER TO RECEIVE DIGITAL TV THROUGH MY DVD/FREE TO VIEW RECORDER I HAVE NOT BEEN ABLE TO RECORD ANY TV PROGRAMMES. THANKS!!!
The tuner in the DVD recorder also needs to be digital. If you have a converter box that would take care of it, otherwise you'll need a new DVD recorder.
Dec 14, 2009 | Radio Communications
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Oct 17, 2009 | Televison & Video
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic recorder
Have you checked your cables? Start resetting one unit at a time until you isolate the culprit. Don't forget the simple unplug all units to let them reset. .
Panasonic DMR-EH55
Motorola 6416 DVR
Sony STR-DA5000
27 analog tv!
Sony 5 Disk DVD Changer
5 speakers
PC connected
You think I have fun when something hiccups? A software snaffu? Bad a/v cable? Loose speaker wire? By the way-my online support is getting better and better. Charter cable has live chat, as does Sony and Motorola. Good luck. Also, I can't think of a single setting I've changed with the Panny. other than assigning digital audio out settings. DEcoder setting? Your Panny?
817-230-4017 if you haven't fixed it.
Dec 09, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Wharfedale DVD-M3 DVD Player Logo
139 people viewed this question
Top Wharfedale Televison & Video Experts
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
