Question about Brother MFC-8860DN All-In-One Laser Printer
Brother Laserjet 8860dn printer not picking up/feeding paper
Printer not picking up/ feeding paper - Boss thinks it is a spring missing When It tries to pick up paper alot of click but no paper fed Is this possible
Thank You
Jennifer
    Problem Solver:
  • 12 Answers
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Posted on Feb 28, 2011
Paper will not feed
Both paper tray and rollers are spring loaded.
If you have paper stuck in the feed area, it will not pick up paper.
Try removeing all from unit and power blowing the inside try area.
Feb 11, 2014 | HP Laserjet Pro Cp1025nw Color Printer
Scansnap S510 does not feed paper
try to check and clean the paper pick rollers
also let me know if the printer is a inkjet or a laserjet printer
Dec 07, 2013 | BenQ Scan to Web 4300U Flatbed Scanner
Printer makes a horrible sound when trying to print also the blue button on the right side making a loud clicking noise. the paper won't feed.8860 dn
I have had the exact same problem. The problem is in the tray. It won't raise the paper properly despite how much paper you have in it. Make sure that all of the springs are there, and that the plastic sensors are correct.
I've found it useful to just buy another tray. You can find it as low as $30-35.
It's a very typical mechanical problem, but most likely resolved by changing the tray.
Apr 01, 2011 | Brother MFC-8860DN Printer
MFC has a clicking sound when lifting paper then reads no paper
try to clear paper feed rolers...remove paper tray, look for rubber, clean it whit wet cloth or alcohol or just repleace rollers whit new ones
Dec 14, 2010 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer showing document jam error
Doc jam error usually means a jam in the adf (auto doc feed) when feeding a fax or doc to copy.
The most common reason brother mfc,s of this configuration have doc feed issues is believe it or not the hinge that operates the lid/adf, specifically the left side one (looking from the front). Inside the hinge there are two springs exerting tremendous force on the hinge (that enables the lid to stay up by itself) however this force eventually slowly breaks the fulcrum point of the hinge which leads to the lid not closing properly which means a sensor under the lid does not activate properly resulting in the adf stopping and resulting in the machine registering a jam. the difference between the sensor activating or not can be as little as a millimeter and is not often disernable. the hinge needs replacing by a techo.
the other reason could be you just have dirty adf feed rollers, clean them with a cotton rag dipped in metho, open the adf lid and give the rollers a scrub. the rollers should have 'tread' on them similar to a tyre, if not they are worn and need replacing.
One other possibility is there may be a paper fragment left over from a jam removal still caught in the paper path and activating a sensor activator that tells the machine paper is coming or going. most commonly in the section where the paper is looping on its return journey back out of the adf, open the adf lid, have a look with a torch and see how you go.
Regards, Andrew.
Dec 04, 2010 | Brother MFC-8860DN All-In-One Laser...
Our Brother MFC-8860DN will only feed paper from
Printers have rollers that grab and feed the paper. They can get dirty over a period of time, or lose some of their "stickiness". Sometimes they're easily accessible, sometimes not, depending on the printer. They can be cleaned with alcohol and q-tip or cloth. The weight of the paper is probably causing just enough resistance to make the printer think there's a jam, but there could also be a problem with the mechanics of the sensor assembly, or a fragment of paper jammed up somewhere. Sometimes you can get it working without taking the machine apart, and sometimes you can't. Make sure you don't void any warranties, of course, but with some investigation, you might get lucky. You've probably done most of what I suggested, but you might take one more look. Good luck!
Mar 24, 2010 | Brother MFC-8860DN Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
How do I get rid of left margin smudges on paper when I use my Brother MFC 8860DN laser printer?
Clean the rollers on the paper path. If it is difficult to reach them try spraying water drops onto some stiff card and feeding it through so it picks up the excess toner on the rollers Just dont make it too wet
Aug 12, 2009 | Office Equipment & Supplies
Brother printer mfc-8860dn
This usually means that it isn't picking up paper at all. Draw and x on the top paper and see if it takes it. You may need a new feed tire or different paper.
Apr 28, 2009 | Brother MFC-8860DN All-In-One Laser...
MFC-8860DN
This is a common issue.
Here is the solution:
Pull out the paper tray
On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
Be careful not to break it.
Oct 27, 2008 | Brother MFC-8860DN All-In-One Laser...
Brother MFC-8860DN All-In-One Laser Printer Logo
307 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
