Question about Dryers
I need to find out what size belt i need for my mcclary dryer
    Top Expert:
  • Dryers Master
  • 76,846 Answers
Model number is required for any parts, the other method is to measure the old belt.
Posted on Oct 01, 2009
I have a McClary Charm A2746 wood stove.I wanted to know what year it is?
Kathy, There should be a certification plate on the stove some where, listing make, model, year of manufacture, etc., open doors/drawers etc. to see if tag is riveted on inside panel or frame. Check the attached links they may help determine the age of your stove, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
McClary Charm A2746 wood stove Google Search
Antique stoves for sale
Ernie Woodstoves Durham Ontario Canada Repairs Restoration Sales
Strong on Stoves
mcclary wood stove history Google Search
Jul 15, 2016 | Home
Needs new belt. Is the belt a common item?
Hello Stevenand266,
I understand that you are having a problem with your dryer, you need a belt. Almost all dryers are belt driven so yes they are common items to a dryer. However, all belts for dryers are not the same size, shape or length. I would be glad to help assist you in your endeavor of replacing the belt if you can post a make and model of the dryer in question.
Thank you for choosing FixYa.com
Justin
Mar 28, 2011 | Kenmore Dryers
GE dryer drum hits idler pulley during rotation.
The belt is most likely either the wrong size (too long) or the belt has stretched. A new belt of the correct size should solve this problem. Make sure you have the model number when you buy the belt. I recommend that you take the old belt with you and verify that the replacement is a little shorter.
Apr 25, 2010 | GE DBXR463EBWW Electric Dryer
I am replacing belt on kenmore dryer but the new one from lowes seems to small are there multiple size belts for kenmore?
You need to match the belt to the specific make and model of dryer. There are several online appliance repair parts suppliers that can provide great assistance, and in some cases, the OEM part number for the belt. With the latter, appliance outlets like Lowes should be able to verify that the belt purchased is the part needed. In addition, check your owner's manual for a specific part number for the drive belt.
Oct 04, 2009 | Kenmore 63942 Dryer
Need a belt for a kenmore 78708 electric dryer
The belt will be a FSP (factory specified part) # 341241
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Kenmore Series 80 Dryer. Heats doesn't spin clothing. Imagine its a belt or spin motor. Need a schematic
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Aug 25, 2008 | Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Dryers Logo
130 people viewed this question
Top Dryers Experts
