The k toner is low and the consumable light is on.
The k toner is low (3k=5%, 1.5k =10%, drum 37%) and the consumable light is on.I am printing in black only but It won't pirnt. It has done a batch and stopped. I am desperate to print some more things out and don't have any toner, is ther anything I can do before I get any toner?
3 Suggested Answers
SOURCE: oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Posted on Jul 23, 2010
tballone
  • 126 Answers
SOURCE: what is the diffrence in
This is the number of pages that can be printed
3k = 3000 pages with a 5% coverage
5k = 5000 pages with a 5% coverage
Posted on Oct 19, 2010
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
Apr 09, 2014 | Dell 1720dn Laser Printer
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
I replaced toner and now light print
you need to replace the K pcu and if the unit has 60K prints all of the consumables need replacing CMYK drums CMYK Developers and the imaging transfer belt and fuser unit
Jul 08, 2009 | Ricoh Aficio CL3500N Laser Printer
Oki 5150 color are not print right
Jun 25, 2009 | OKI C5150n Led Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Drum and toner led blinking
I have the same problems with you guys, and none of the solutions above work.
I solved Brother HL-2040 with the following tricks
1. Use the link below to process steps 1-4 and stop.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000017/faq002517_001.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
2. Use screw driver to remove 3 screws on one side of the toner
3. From the small separate part after removed it from the toner, there is a small white adjustment (plastic), use your finger adjust to the opposite side. Put it back to the toner, and screw them back as original.
4. Follow the remain steps from the link above,
Your toner indicator should be turn OFF
Regards
Vu
Jun 18, 2008 | Brother HL-2040 Laser Printer
Drum light on Ready light on Alarm light on Data light on
Alarm and Data lights on together is from low toner. If shaking of the toner cartridge is not helping, change the toner.
Drum light is usually on because of the print counter. If the print quality goes really bad, change the drum and reset the counter by holding the front button wile the front cover is open till all lights come on. Release the button and close the cover.
If just Data light is on, check the print ques, some jobs might got stuck there.
Apr 28, 2008 | Brother Office Equipment & Supplies
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
22 people viewed this question
k24674
jasbo
jasbo
