DeLonghi DEBIGE 2440 Electric Double Oven
Re:Electric Convection oven does not heat up....
posted by anbiggs on Dec 20, 2007
When attempting to turn on the top electric oven only the convection fan spins but no heat comes out of the electric burners.This is a brand new oven and should work after installed. What could prevent the filaments from heating up?
( The lower gas oven works well. )
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 21, 2007
Helpful (85)
Bob from LI
Rank:Guru Guru
Rating: 85%, 561 votes
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Re:Electric Convection oven does not heat up. Convection fan works, light works.:
I don't want to Accept this solution
Can you Help with these Ovens problems?
setting the timer on a delonghi dual fuel
my oven fan sounds like its vibrating when reaching...
Electronics on this range is saying f-1 on the...
what does each one mean?
fan assisted function on bottom oven being overridden by...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
