Question about VinoTemp Refrigerators
Vinotemp VT-12TEDS beeps constantly and the temp not working
Vinotemp VT-12TEDS beep constantly and the temp control will not come on nor the inside light.
3 Suggested Answers
SOURCE: My Vinotemp VT-12TEDS has no front panel lights or
I also have the same problem and am looking for a solution short of buying a $35 replacement board with $10 shipping for a fridge that costs $60 new.
Posted on Nov 07, 2009
  • 11800 Answers
SOURCE: I have a Vinotemp VT-12TEDS-2Z Dual Zone
This cooler uses the Peltier effect = the current passing thru a very special resistance provides the cooling. Because of that there are effectively 2 separate electrical circuits inside your cooler:
1, the mains voltage that powers the Peltier element and the cooling fan - controlled by a relay
2. the low voltage that powers the control board and the display - this is the one that failed in your case.
To fix it you will have to open the front cover , access the board and test it: if it gets power then the board itself has failed; if it doesn't then its the power source and you will have to find out why it failed - probably it was damaged when another component failed and you will have to find out which one before putting a new source in.
It's a relatively complicated job that requires a good experience - if you don't have it then call an certified repairman.
Posted on Jan 08, 2011
Chimes constantly. How do you turn them off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
Remote is emmitting a constant beep
The remote control works well, emits infrared rays, but there is some fault with the infrared sensor inside the device. Check it. Contact any service technician. The remote control do not get a reflex signal from the host equipment.
Gopakumar Gopalan Google
Mar 27, 2014 | Pioneer New Original AXD7265 Remote...
My vt-tc32g will work for a bit and then stop
If it cycles very irraticly then the temp control could be out of calibration and will need to be replaced. There usually is about a 5-10 degree difference between on and off for the temp control and will be worse with no product in the cooler
Sep 06, 2012 | VinoTemp VT-TC32G
Tc32g unit gets too cold
Too cold usually means temp control switch is out. Temp controller turns the compressor on and off based on the temp. It can be a mechanical switch or a circuit board, but good chance it has failed.
Mar 29, 2010 | VinoTemp VT-TC32G
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
My Vinotemp VT-12TEDS has no front panel lights or temperature reading. The unit flashes the red and green LEDs and clicks in sync with the flashes. The external cooling fans attempts to move, but does...
Oct 04, 2009 | Refrigerators
This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
My vinotemp will not stop when it gets to 55 degrees - it keeps running and starts beeping when it gets into the 40's - it is a 2 door 500 bottle model
Check the coils to ensure they are free of dust(can be vacuumed) and the doors on the unit are sealed properly. Sounds like there is a thermostat problem. You can get these parts from Vinotemp @ 800-777-8466
Jul 15, 2009 | VinoTemp Refrigerators
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
Refrigerators Logo
258 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
