Question about Toshiba Satellite A215-S7422 Notebook
My A215 wont stay powered up. It shut down and
My A215 wont stay powered up. It shut down and now it starts to boot and then the power just turns off after a couple of seconds. Is it a bad power supply, and can it be replaced. I had to replace my power cord a week ago because I could not even get power to the computer. It has been working just fine since until today and it just decided to shut down and now I can't get it up and going again.
  • 448 Answers
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Posted on Oct 01, 2009
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
My laptop wont turn on
You may have a RAM problem. Try reseating the RAM modules, if this does not fix your problem, remove the RAM modules and take then to your friendly computer repair shop and get them to test the RAM for you.
Feb 06, 2012 | Acer Aspire 5520-5908 Notebook
Nothibg I do will take me to the boot options screen, It just stays on the opening Toshiba page.
For entering the Toshiba BIOS....
while the system is powering on
1. try pressing Esc and if nothing happens
shut-down and then power-on again
2. try pressing F1 during this power-on
Hopefully either 1 or 2 gets you into the BIOS
Feb 11, 2011 | Toshiba Satellite A215-S4807 Notebook
I have a satellite A215 - s5818 It started with it just shutting down all of a sudden . reboot and it may work for a while and it would shut down again . Now I can hear it power up but no display on...
his is sound as though your power adapter is not charging your laptop battery and the battery is trying to preserve what power it has left to power up the screen as you demand but there is no voltage to do so.
1. you will need another power supply adapter from what you have describe here and or a battery replacement.
if you can possibly get an equivalent power adapter for your unit and connect it to see if you get power up then you need to replace the power adapter.
I hope this helps. Have a great day!
Oct 05, 2010 | Toshiba Satellite A215-S5818 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby modes....windows hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
The laptop wont boot up.
remove battery and test it if doesnt work try to test it by another power adapter.
Aug 05, 2009 | Toshiba Satellite A215-S5822 Laptop
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
Shuts down
thank you for your response....I'm using Vista and the power seems to be on but the screen is down. I have to hold the power button down for 10 seconds to shut down then turn it back on to restore the computer. It is a Toshiba A215-S5818
Jun 18, 2008 | Toshiba Satellite A215-S5822 Laptop
Pc wont stay on
check your power supply,earhing problem .proper voltafe .
clean your ram,processor and its position.
check that your bord dont touch the cabinet.
other wise i think your bords register or diode transistor are corrupt.
repair your motherbord chipset if above try are not succes
Apr 01, 2008 | Soltek SL-86SPE2 Motherboard
Toshiba Satellite A215-S7422 Notebook Logo
191 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
