Question about Biostar K8VGA-M Motherboard
Windows setup does not see sata drive K8VGA-m
After a virus crashed the systemax computer I can not runn setup from the Windows Xp sp2 disk it will not find any hard drives attached to the computer
  • 979 Answers
Good day sir, if your hard drive is bad it cannot be detected, but lets review first several reasons why it cannot be detected by your motherboard;
  • check the master / slave setup, if youre hard drive is sata, this is not applicable.
  • check your connection, both data and power cable, to and from the hard drive. (ribbon ide cable or red sata data cable)
  • Still cannot be detected? try to reset your CMOS setup by using the cmos battery jumper. after reset, review the CMOS settings, and enable your IDE/SATA drives. test again.
  • Stiil doesn't work? bring it to a friend who has a PC and try to test your hard drive to any available good PC, to check if your drive is bad.
If your hard drive is good, chances are your motherboard IDE/SATA part is bad, you may need to buy a PCI to SATA/IDE card. connect this card to any available PCI slot, connect your hard drive. hope this helps.
Posted on Oct 02, 2009
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Apr 06, 2012 | Systemax Venture S519J (988868) PC Desktop
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
My hdd does not get detected
I too had a similar problem with my laptop. My laptop had a virus attack and somehow I managed to remove all the viruses. However there was one persistent problem which was while booting, My documents used to open automatically. Hence I wanted to repair the Windows XP SP2 and so I went to BIOS and changed the settings to boot from CDROM. While booting the installation CD from CDROM, suddenly I get a message: Hard disk not found! This was nightmare. Then I got this solution:
My laptop was new and the HDD was connected to motherboard with SATA, and we need SATA drivers before installing OS. In the likely event of not getting this driver, we could still solve this problem by confusing the computer. Go to BIOS settings and change the SATA to IDE or any other. Then restart the computer. The HDD now can be seen and you can repair or reinstall the Windows XP SP2.
Aug 12, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Installing XP pro on my presario C700
restart the machine and press f10 to enter BIOS.
select exit and select load setup default. and exit.
install Xp Opearting system
May 29, 2009 | Compaq Presario 700 470024-192 Notebook
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Jan 17, 2009 | Biostar K8VGA-M Motherboard
Hard disk problem
hmmm try to make SATA disabled from your BIOS setup. Because windows XP SP2 don't have any SATA driver, its came up with only IDE.
Try to disable your SATA it will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
How to install Windows XP Professional SP2
Check this Sol'n..
1. Boot(start) ur computer.
2. Press F2 to open up your BIOS Setup
3. Go to boot menu and set the 1st boot order to CD drive using function key. ex. F5
4. Change the SATA settings to IDE. Not
5. Save the new settings using function key before exiting. Ex. F10
It will restart and surely boot on your XP cd (if inserted)..
The rest are typical OS procedure.
From
#14DeeP
CCC-OTC Computer Operator
Mar 09, 2008 | Computers & Internet
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Biostar K8VGA-M Motherboard Logo
448 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
