Question about Pioneer CT-W205R Single Dual Cassette Deck
Problem with deck B on Pioneer CT-W205R
Cassette B will not record or play, but will fast forward and works perfect in reverse.It done well for some time and just seemed to fail recently.
    Problem Solver:
CANT RECORD FROM CASSETTE TO CASSETTE,. INPUT LEVEL IS WORKING
Posted on Dec 22, 2011
    Scholar:
  • 79 Answers
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Posted on Mar 21, 2008
Where can I get replacement belts?
They are hard to find but try the MCM Electronics catalog. You will need to know the dimensions of the belt (i.e. width, length...).
Good Luck !
Apr 25, 2016 | Pioneer CT-W205R Single Dual Cassette Deck
Why one tape at deck A won"t come out. it stock inside unit
There are lots of causes to this. For example the mechanism has jammed. The tape has become entangled in the capstan or elsewhere. Plastic damage causing the mechanism to not move back to the eject position. Some decks have a powered eject that is faulty. Broken spring, or one that has fell off.
May 28, 2014 | Pioneer CT-W205R Single Dual Cassette Deck
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Deck plays forward, fast forward and fast reverse O.K., but does not play backwards.
I don't have any quick answers as this is a newer deck than when I worked for the company- I would have to see the deck to determine the fault. Do you have the continuous reverse switch on -maybe that is it.
Oct 19, 2010 | Teac R-H300 Dual Cassette Deck
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Faulty Pioneer CT-W450R
Check to see if their is any voltage going to the motors. If not look at the power supply. Electrolytic Capacitors dry up when not being used and can cause faults like that.
Jan 23, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Faulty CT-W450R
The rubber belts inside the unit have gotten stiff and slippery. All belts should be replaced. That will resolve the problem.
Dan
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
568 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
