Question about Refrigerators
How much oil if any should I add to the system after vacuuming down and recharging with freon?
  • roger_bri797
    roger_bri797 Oct 01, 2009
    Thanks...Very fast !!
  • Refrigerators Master
  • 3,361 Answers
Your question was posted under refrigerators. I am answering based on a domestic home type refrigerator.
Unless you have a oil injector you would have added oil before the vacuum process while the system was open. If you installed a new compressor it came fully charged with oil. If you simply repaired a leak it is unlikely the old compressor lost enough oil to matter.
It you have a oil injector and want to feel safe you could add up to 2 ounces of oil.
If you have not yet vacuumed the system and it is still open,you could pour 2 ounces of oil into the low side port.
Posted on Oct 01, 2009
AC was working fine but now just blows hot air?
check Relay. If its good then it may need recharged with freon.
Jul 09, 2017 | AC Cars & Trucks
How much Freon and oil do I need to add to a new used compressor
13oz of PAG46 oil. Be sure to vacuum down the system after you put the oil in. Let the vacuum pump run for about 30min or more.
Then roughly 46oz of R134A but you want to use gauges so you dont over pressurize due to ambient temperature.
Sep 02, 2015 | 1998 Dodge Ram 1500 4WD
How much Freon and oil to put in a new used compressor
These dont use Freon. Freon is R22
These use R134 -46oz and 13oz of oil. You need to pump down the system though once the oil is added and let it sit with the vacuum pump to remove any moisture. Any moisture left in the system will ruin your expansion valve and compressor quickly. Then add one can of R134 and run the system for a minute to distribute the oil. then add more R134 until the gauges show it at the right pressure for your ambient air .
Can the freon be recharged on my ac
Yes, are you asking if you can do it though?
Jul 16, 2014 | Cars & Trucks
Recharge freon in 2006 jeep liberty diesel
You will need a system evacuation pump and gauges do you have these tools? If not let the pros do this recharge or the compressor may fail again. Did you add AC PAG oil to the system?
Jul 03, 2012 | Cars & Trucks
I repaired an AC leak, vacuumed the system down for 8 hours and am ready to recharge. How much oil is normally (lost) do I need to replace with the freon R134? Is more oil lost in a big leak like a...
Did you repair the leak? You need to before you do anything. You must do a full oil and freon recharge after vacuum. You can find places that will refill with R-12 or equivalant. R-12 operates at a lower ppressure and cools better without replacing any other parts.
Aug 10, 2010 | 1991 Mercedes-Benz 560
I am recharging the ac system in my '04 Blazer and need to know how to add oil to the compressor.
If your just going to recharge it and nothing was replace, no need to add oil, freon will have some oil, if you replaced the a/c compr. before installing the hoses to compr. add oil into compr.
Aug 07, 2010 | Chevrolet Blazer Cars & Trucks
Air cond compressor oil
mcdevito75 here, Almost all Freon contains some compressor oill, pick up a recharge kit from your local parts store. If you a/c system has been down for a while you could add a can of oil it comes in one size, and usually added before ar during the freon charge.
Jun 16, 2010 | 1996 Ford Taurus
I was just recently in a car accident. My raditor broke and had to be replaced. Because i didnt want to pay a mechanic to do it i did the job myself. It worked out well but after dissembling it the coolant...
first you need to find out why the freon leaked out then repair that, then you will need a vac pump to vacuum the system for about 45 mins then if you lost oil add a couple of oz,when you lost the freon if there was a cloud of oil and gas then add 2oz before the vac down while system is open put into line or dryer or condensor, after the vac, then recharge to spec, there a label at the radiator support or on the hood that tells you how much freon the system holds,here you go it holds 1.48lbs of 134a freon.
Jun 16, 2010 | 1998 Saturn SL
Cool Tech 34700Z Recovery, Recycling, Recharging: when I have the system in a vacuum the liquid freo...
I don't think your machine have any problem! But if you are sure then you can rebuild oil drain solenoid.
May 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
